Question about Ovens
Eurolec fridge freezer rf010 light/ thermostat unit replace
Where can I obtain an Instruction manual for a Eurolec built under oven with grille?
Looks like the support is overseas. However they do have email support. If I knew the make and model I might be able to obtain more information. Otherwise here is the email link for support:
Reception@Eurolec-Services.co.uk
Jul 02, 2015 | Ovens
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
Lamona fridge freezer
check that the temp setting knob has not been turned to zero for the fridge. The light is only to let you see what is inside the fridge and is not an indicator of the fridge working.
Jun 26, 2013 | Ovens
Ref/freezer not cold , even at coldest setting. Seems bottom oo fridge/frrezer colder than the top.
I have had a similar experience. Ice may accumulate inside the cabinet, adjacent to the thermostat, even on "frost-free" models. This can be especially troublesome if your home or climate isespecially humid. The ice tricks the thermostat into thinking everythingis cold enough, so the cooling unit simply does not turn on, and when it does come on it only refreshes the ice. Your first thought may be to defrost the fridge. You will have to empty the fridge, then leave it unplugged for a day or two. Be prepared for the melt water, it may run out of the cabinet and flow onto your floor. If this does not help, you will probably want to call a service tech, as fridges do wear out. But do your homework, new refridgerators have come way down in price, and there are incentives in many jurisdictions to encourage you to replace older units with newer, more efficient units. You may find it is a better idea to purchase a new one. I hope that this is helpful, Rob.
Jan 01, 2011 | Ovens
My eurolec oven is letting the heat out and burning the cupboards
check that the fibre glass is still in place and has not been soacked with water, you can get some fibre glass from your local stores and wrape it just after openning the couvers and puting them back to place
Aug 02, 2010 | Ovens
Water works but icemaker does not. the freezer barely cools
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 11, 2009 | Ovens
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
GE Monogram Fridge/Freezer
A frosty freezer in the back panel is an indication of a defrost failure issue. Problem may lie in the the control board, heater or defrost terminator. The problem usually is a broken defrost element. Hope that helps :)
http://tclaundryrepair.com/
Feb 25, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Eurolec oven fire - gases released made us sick
Good morning Folk!!
A toxicity doctor rang me to say that I have been exposed to vitreous enamel and galvanised metal.
The composition has zinc, chromium, silica so when the gas came off the oven interior, I had "gas fever, short term toxic, that would be eliminated from my body with no expected problems. Apparently welders have this all the time. It causes irritability, nausia and sleepiness. Australia has very poor metal detection in blood testing. It usually has to be sent to America.
I don't trust Eurolec, nor the company who made their baked enamel ovens - Technogas Italy, who now produce for Euro appliances.
I'm getting a new stove - ILEVE - which is a better quality gas stove all round.
Bye for now
Sandra Petersen
Sep 17, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
