How do you clean the filter on a whirpool awo/d4605
    Brigadier General:
  • 6,277 Answers
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
AWO 3551 have a FP fault . help
thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
Feb 21, 2012 | Whirlpool Washing Machines
I need the user manual for a Whirlpool AWO/D4605. Can I download it for free from somewhere?
Hi Carol from retired Englishman in SW France,
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 20, 2011 | Washing Machines
Require owners manual for whirlpool washing machine awo/d4605
goto this link and enter the AWOD4605 in the code area, choose the language that you want, and you will be given a choice of 2 manuals (at least for English) to download / view.
Sep 10, 2010 | Washing Machines
Manual for Whirlpool washing machine AWO-D4605
the service spanner has come on and my machine wont work it is a awod4605, it has been serviced but our engineer is on holiday so we are stuffed as we dont have the manuel to be able to disingage the service spanner help.
oh its a whirlpool
Aug 25, 2010 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
How do i clean the pump on my whirlpoll awo 3551
Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Jan 25, 2018 | Washing Machines
When on its final spin cycle washer does not spin at its normal high speed. it is three weeks out of warranty! I can't see anything mechanically wrong, so i'm assuming it has a self destruct program! Will...
REPLACING THE CIRCUIT BOARD SHOULD BE YOUR LAST RESORT.YOU NEED TO CHECK THE MOTOR WINDINGS ON THE MAIN MOTOR IF THEY OK THAT CAN ALSO CAUSE THE MOTOR NOT TO SPIN TO ITS FULLEST ALSO CHECK YOUR CAPACITOR IS OK.GOODLUCK. MOAHMED
Sep 11, 2008 | Whirlpool Washing Machines
How to clean the pump on a Whirlpool AWO/D4605 washing machine
Hi, you can sometimes see the important bit of the pump - called the impellor - when you remove the filter from the bottom of the machine, It is usually behind the panel below the door.
If you peer in there with a torch, that missing sock might just be within reach with a pair of pliers or some kind of hooky thing.
But take care, if the pump is jammed the machine might have wuite a lot of water in it, which will want to come out when you remove the filter. (Unless you pull the machine out from under the work surface and tilt it backwards against a wall or friend.)
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please delay the rating and add a comment
with more details so I can try to help you further. Cheers, D
Jul 10, 2008 | Whirlpool Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
