Question about Dryers
My Fisher Paykel Smartload dryer is not drying. I took the front off and the flame comes on and then about 30 seconds later it goes out, then it will come on again. Almost as if its going through a cycle. Is that how it is supposed to work or is the flame supposed to stay on the whole time? I have the dryer on regular dry. The problem is it is not drying the clothes, I open the lid and the clothes are a little damp and cold.
  • Rodney Myers Mar 18, 2011
    Are you talking about the gas dryer ignitor because I went to the link and they did not list the coils? I tapped on a switch that is on the front and also on what looks like a pressure switch where the gas comes in and it started working. The flame still kept going on and then off but the dryer was getting hot. I have a DGGX2US model dryer.
    Thanks
  • Rodney Myers Mar 21, 2011
    Thanks very much for your help. I appreciate it.
    Guru:
  • 262 Answers
Rule of thumb for gas dryers...If the dryer turns but never produces heat then check the fuse.If the drum turns and you get intermittent heat,ignitor comes on but goes off without flame coming on or "my dryer takes longer to dry my clothes then check the gas valve coils first.
Sounds as if it is the gas valve coils
Here is a link where you can input your model number and your parts drawings will come up. I would have done it for you but the model number was not posted.
click on the link http://fisherpaykelparts.net
Posted on Mar 13, 2011
  • 1 more comment
  • Keith Drake
    Keith Drake Mar 18, 2011
    here are the part numbers on the link I posted.
    DE382 Gas Valve Coil Kit
    The model number you posted will not come up. You will need the complete model number to ensure the proper parts.
  • Keith Drake
    Link for all appliance model numbers.
    Please post your entire model number.
    After you have clicked on the link below....
    Just to the right of the "search" tab click on "help me find my model number"
    Just click on the model of your choice In either video or image presentation
    Then please repost the information.
    Click on the link http://www.repairclinic.com/Appliance-Pa...
    Thanks....
    Keith
    Click on the link http://www.repairclinic.com/Appliance-Parts
    Thanks....
    Keith
  • Keith Drake
    Quick info tips....
    Q - Dryer takes too long to dry or multiple times to dry a load
    A1- Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
    A2 - If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Fisher paykek smartload dryer made loud noise while drying now does not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Fisher and Paykel Dryers
Top load Fisher Paykel dryer doesn't get real hot and therefore is very slow to dry clothes. I've checked the lint filter and the exhaust pipe is clear, so air is moving freely through. It seems it must...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Fisher and Paykel SmartLoad DG62T27G Dryer
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I recently had a horrible repairman recommended by the company come to my home to fix the dryer because it wasn't drying properly. Not only did he lose a screw in the front and not replace it (the front is...
Is it still not drying? This happens when the heating element goes out and can be replaced by yourself and the heating element coil is about 20 dollars. I'm not sure which wire is not connected, probably connects the button that shuts off when you open the door.
Mar 01, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
Heating element no longer working. dryer still operating except clothes wont dry
it is the theromstats or heater element has gone the only way to tell is to meter them out u need an expert to do this
Jul 31, 2009 | Fisher and Paykel SMARTLOAD DE62TG1...
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
164 people viewed this question
Top Dryers Experts
