Question about Activision History Channel: Battle For the Pacific for PlayStation 2
I have installed battle for pacific on pc but when i start it gives error "bftp.exe has stopped working"what's the problem
I cant run cricket.exe in my windows 7 ultimate ..im using sony vaio laptop it is giving error like"problem cause stop working " please give me solution as early as possible
try to reinstall the software but first you need to remove it completely. You can use revo uninstaller to completely remove the application and its safe to use. After uninstalling the application, restart the laptop then reinstall cricket. hope this helps
Feb 09, 2013 | Computers & Internet
Camera launcher.exe does not work anymore
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
Nov 20, 2011 | Canon Digital Rebel XT / EOS 350D Body...
When i start cricket revolution ,an error appears that "no internet connection found" but i'am having a working internet connection
i have installed the cricket revolution game on windows 7 but when i launch the game its show the 'cricketrevolution.exe has stopped working' and 'could not copy' error message .. so pls tell the solution plsssssssss
Mar 04, 2011 | Mindstorm Studios Cricket Revolution
The file "msvcr80.dll" is missing . I can not load the disks on call of duty 2
it is a installation error.....try installing with another disc..
Oct 10, 2008 | Computers & Internet
When i go to pressplay acertain game it tells me prism3D.exe is not working
Believe it.  Go check that certain game to see if its install somehow missed prism3d.
Oh, and you're a tosser for not giving the actual error message.
Jul 22, 2008 | Computers & Internet
I have a recording software called Sonar 6 and every time i try to start it, i get an error message saying "sonar has stopped working". I have had the software for a few months and it's only just...
HAI,SONAR 6 SOAFTWARE WORKING PROPERLY IN THE MIDDLE IT'S NOT WORK OR FIRST YOU HAVE INSTALL THE SOAFWARE THAT TIME WILL NOT WORK.ANY WAY UNINSTAL SONAR AND REINSTAL IT'S WORK FINE.
UNINSTAL :
START>CONTROL PANNEL>ADD REMOVE PROGRAMS>SONAR>REMOVE.
RE-INSTAL :
DOUBLE CLICK FOR EXE SETUP PROGRAM FOR SONAR>SELECT TARGET AREA(DEFAULT C:\)>FINISH.
RESTART SYSTEM AND USE SONAR.
Jul 05, 2008 | Computers & Internet
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
May 01, 2008 | Computers & Internet
Funny UST scandal virus
first download taskiller in http://www.rsdsoft.com/task_killer/index.php4
and install it to
your computer because you cant use taskmanager to terminate the virus(the
virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Note:
If you have problems opening drives in My Computer open regedit find
"\smss.exe" then erase values like: "c:\smss.exe", "d:\smss.exe" etc..
Hope this helps
Jan 16, 2008 | Computer Associates eTrust PestPatrol...
Activision History Channel: Battle For the Pacific for PlayStation 2 Logo
87 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
