Question about Maytag Refrigerators
Water puddling in botom of freezer and runs in floor periodically (maytag side by side)
I had a problem like yours, the auto defrost doesn't always turn off. On mine I replaced the sensor. it was a round sensor clipped to the top of the freezer condenser, kind of hard to get to to replace. inside the freezer at the top it has two wires. I ordered mine from sears parts. I don't know if thats your problem, but sounds like what happened to me.
Posted on Mar 13, 2011
Periodically I find a small puddle of water under the freezer portion of the side by side. Puddle spreads out about 18 inches. I've taken the back off looking for obvious water marks but can find...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag Plus side by side Refrigerator MSD2756GEQ. Every couple of days there is a puddle of water on the floor on the freezer side door. What can I do to fix this problem?
ck the bottom of freezer and if ice is there . the drain is pluged and water is running out the door on floor . every 8 hr of compressor run time the unit will defrost and water on froor .
Aug 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
An occasional water puddle appears below the freezer door. a thin layer of ice builds up on the floor of the freezer section.Any ideas?
The drain is plugged and instead of the water draining into the drain pan it's running into the freezer.Usually the owners manual can help with suggestions for clearing the drain depending on which model you have.
Mar 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water on floor from freezer side of Maytag side by side unit.
Yes I just had that happen to me. An appliance guy came over for my stove and I asked him if he could tell me why I wake up everyday to a puddle. He told me to take the baskets out unscrew the three screws and pull the panel off, then pour some hot water in it and use a turkey baster to blast the drain hole with. It worked. Sears repair man couldn't even figure that out when it was under warranty. Took me 15 minutes. Good Luck
Connie Marie
Aug 12, 2009 | Maytag MZD2766GES Side by Side...
Water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Jan 30, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
