Question about Timex 1440 watch
How do I turn off the hourly chime? - Timex 1440 watch
How do I turn off hourly chime?
Your watch could be defective but at the point where you turn off the hourly chime, check the face for a symbol that disappears.
Dec 18, 2015 | Puma Faas 200 Sport Watch
How do i turn off hourly chime on a timex marathon t5k423
To turn off the hourly chime, just press the MODE button (bottom left) until the watch is in alarm mode. Then press the ST/STP button (top right) and the icon for hourly chime should go away.
May 10, 2011 | Timex Watches
How do I turn off chime?
Hello Mfchester,
Here are the instructions to turn off the chime on your Timex Sports 1440 watch. Please let me know if I can be of further assistance! :)
--Sandy
ALARM AND HOURLY CHIME INSTRUCTIONS:
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off.
  6. Press START/STOP again to turn alarm on /off.
  7. Release START/STOP when done.
Note: Please remember to rate this post if you found it useful.
Apr 19, 2011 | Timex 1440 Nylon watch
How do I turn off the hour chime on a ess watch ?
Press and hold the bottom right button; this displays the alarm. At the same time, press the bottom left to toggle the hourly chime. When the chime is enabled, the 'day of week' display at the top of the dial will show all days as selected. When the chime is disabled, no days will show as been selected.
I have one of these watches and it took me a while to find this out!
HTH
May 17, 2010 | Watches
Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
I suspect that the mechanism needs cleaning.
Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
May 01, 2010 | Watches
Kenneth Coleman Watch Beeps Every Hour! It Needs to STOP!
think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
Mar 27, 2009 | Watches
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Aug 12, 2008 | Timex 27191 Wristwatch
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Timex 1440 watch Logo
132 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
