Question about Siemens Dryers
Trying to find a manual in english for a Siemens tumble dryer S46-58 its a 8kg front-loader - many thanks for any help
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
TheMobilian
  • 8220 Answers
SOURCE: old kenmore gas home dryer front loader will not heat
read this
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 08, 2009
vickygomar
  • 460 Answers
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
Posted on May 21, 2009
SOURCE: Hi, My 8kg Hoover Tumble dryer Vision HD stopped
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Posted on Jan 11, 2011
How do I change the language setting on the Siemens S16-74 Front Loader back to English?
If you can identify the current language setting, you can try an on-line translator of the menu items to determine which one is for language settings.
Alternatively, you can download the user manual for your appliance and look up the language change procedure there. The menu items are almost certainly arranged in the same order in any language, so it would be a matter of keeping track of where you are in the process.
http://www.siemens-home.bsh-group.com/uk/customer-service/user-manuals
Oct 19, 2017 | Siemens Cell Phones
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
How do I find a siemans tumble dryer manual
A google search, with the model number and the words ''user manual'' will very likely turn one up for you.
Aug 17, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
My Siemens IQ-700 tumble dryer not heating during drying cycle. It is a WT46W572DN/16 condenser model. How can I reset it? Is there a high heat emergency switch somewhere in it? Any source maybe for a...
Ok there could be several things preventing it from heating, here is a list gas valves, heat limit switches, bad thermostat, bad sensor. Time to open it up and get to testing. Sorry but this not one with a simple answer..
Apr 18, 2014 | Siemens Dryers
Have bought a LG 8001a dryer in France Looking for English instruction manual
Go to the following website and you can download the manual. It is the same manual for 8001a, 8001b, 8001c etc.
http://www.lg.com/uk/home-appliances/tumble-dryers/LG-black-tumble-dryers-RC8001B.jsp
Jan 29, 2011 | Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
Dryer won't start
hi thanks for the question theres a small thermal fuse located under the door behind the panel to get access remove front bottom panel 2 screws at bottom of panel and on the air duct to the left theres a small thermal fuse check it for continuity if bad replace thanks the appliance doc
Aug 20, 2008 | Kenmore 62872 Electric Dryer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Dryers Logo
87 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
