Question about Panasonic TH32LRU20 32 in LCD TV
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc manually. It started playing up yesterday. All the volume, brightness, sharpness ect bars were coming up on the screen all by them sevles without me touching anything. And now today it just wont do anything. We bought this tv less than a year ago, brand new! PLEASE HELP!! Regards Kelli
  • fullerlax451 Apr 09, 2014
    Have a techy friend or your husband take it apart and peak around in there. You can carefully watch the tvs functionality if you plug it in with the cover removed, just be careful.
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
Posted on Apr 26, 2011
Replaced battery now nothing works,doors dont unlock,car doesnt start,no sounds when pressing buttons although it still sang when battery replaced,pressed "P" button hoping it would do something and now it...
The waves mean that the remote is vibrate mode. Try reprogramming the remote. Open the door, turn ignition on, press and release the valet button once then, press and hold the valet button. press the lock button on the remote. Vehicle should respond with a chirp from the siren. Release valet button, turn off ignition, test system.
Jan 17, 2014 | Directed Electronics 479V Remote Gen 2...
I haven a RCA RCU704MSPZ universal remote control. Can you please help me get the code to use with my panasonic vcr? Thank you Peter G.
The Panasonic VCR remote codes are 008,053 for that remote. You may also try using code search. I have outlined the procedure below.
Programming a Device using Code Search:
Manually turn ON your device (TV, VCR, Cable Box)
  1. Press and "HOLD" CODE SEARCH
  2. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  3. Release CODE SEARCH.
  4. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  5. Once the device turns off, press and release ENTER.
  6. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Dec 22, 2010 | Televison & Video
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 24, 2008 | RCA Universal Remote Control
Panasonic TH32LRU20 32 in LCD TV Logo
220 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
