Question about Kitchen Ranges
WHIRLPOOL FRIDGE S/S MODEL #ED2FHGXKQ00
Thanks prince p for the help i ordered the part for my stove i also have problem with my whirlpool side by side fridge model #ED2FHGXKQ00 SERIAL # SM1841062
the ice maker deos not get water so there is no ice, i checked the water supply there is water coming to the fridge i can get water from the water compartment but the pipe which attached in the back of the fridge which supply water to the ice maker there is no water in that pipe. what do u think could be wrong. thanks for ur help.
  • yamanayeemi Aug 06, 2008
    thanks prince p I got the oven sensor and replaced it, but still the the code f1-1 is appearing on the screen panel and asks me to call for service when it gets hot no matter if i use the element on the top or the ovens it seems when it heats up the problem starts. again model # mer6770acw and also i am going to work on the fridge too thanks for the help.
  • yamanayeemi Aug 08, 2008
    Hi prince p how change the limiter and where it is located in the stove, would you pls tell the instalation procedure thanks
    Scholar:
  • 93 Answers
Hi Yamanayeemi,
"Dont forget to rate my solution to your STOVE!"- Fixya or helpful?
Before attempting any testing or repairs. unplug your fridge.safety first.! avoiding an electrical shock hazard.
It might likely be your water inlet valve that is bad , corroded or clogged.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink).
Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires.
The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors.
Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting).
Place a probe on each terminal.
The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Does my suggestions help to solve your problem?
Posted on Aug 03, 2008
  • Femi Omojogberun Aug 07, 2008
    Try to change the LIMITER Item # 704502, the price $52.85 on repairclinic.com. that should correct the high Temp you experienced.
Ice lump build-up on left side of the lower back panel inside the fridge section of fridge freezer. Compressor is on continuously. Any help appreciated. Thank you.
Check the operation of the thermostat. Try raising the temperature og the refrigerator side and see if the compressor stops.
Oct 30, 2017 | Whirlpool Refrigerators
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
I lost my label tag for whirlpool refridgerator. I remember the year was made 1992 but don't remember the model number. It is a side by side fridge. Can someone provide a possible model number for me?...
Hey John,
Do you have your manual? There are about 5 billion Fridges with the exact measurements you gave! You know its a whirlpool from the 90's....have you gone to the whirlpool web site and checked there?
This is what I found there:
http://www.whirlpool.com/catalog/product.jsp?src=Search&categoryId=96&productId=1897
What part do you need?
Mar 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Fridge and stove side by side
I would get a piece of styrofoam insulation like they use on houses. It's about 1 inch thick and you can cut it to fit and paint it to match. Other insulation solutions should be available at Lowes etc.
Sep 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool regulator
Hello arizonascrat
Welcome
You said You just bought a whirlpool gas stove, but it is set up for natural gas and you need it to be for propane gas. How do you do this? Do you have to purchase anything, if so where? Whirlpool GR 465 LXLS THANKS, in advance, Norma
They make an LP conversion kit What you are asking and it should cost only about $20 dollars.
One Model # is, 8576846A
Now some places have it using different numbers!
Make sure to ask if this is for you range. I believe on kit fits all Whirlpool Gas products.
We have sponsors here on fixya that you can order this from.
One I believe is the repair clinic.
Thank You for using Fixya.
Huuum
Please remember to leave me a solved rating!
Oct 12, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
CODE F1-1 STOVE MAYTAG GIMENI/ WHIRLPOOL S/S NO ICE TO ICE BUCKET
Sorry i still have this problem with code f1-1 appears on the screen panel especially when it get warm or hot and still need help. thanks
Aug 08, 2008 | Kitchen Ranges
Hi where can I obtain spare parts for a whirlpool fridge model # wrx38rwh6 - I am after a bottom, shelf, vegetable crisper and big milk side shelf. Do you know the price? Thanks Tara
Check phone book for local part distributor or repair facility, most repair shops sell parts. also check links on this site for mail order.
J
Jun 12, 2008 | Whirlpool Refrigerators
The missus destroyed the fridge door drink shelf , its a whirlpool WRX38RWH6 . thanks for any help
A whirlpool dealer should be able to order the part you need short of replacing the whole door. Give them the model and serial number of your product. Whirlpool also provides a 800 help line which should be listed in your owners manual. Give the girl a break as things happen.
May 07, 2008 | Refrigerators
Kitchen Ranges Logo
189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
