Question about Sony PlayStation Portable (PSP) Console
Jose how you cut the gold line
  • 135 Answers
Just run your cutter on it a few time...maybe 15 to 20 cuts will do? just be sure not to cut through the circuit board of your batt or it'll of course be a total mess...you wont be able to use it again...
Posted on Aug 01, 2008
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
The water lines from the filter housing leak at the solenoid and are dripping at the filter. It is a Whirlpool gold series side by side
you should be able to push in the ring around the tube at the same time pull the tube out
cut about 1/4 in off and push it back into the hose clip
unless your line is craked this should work for most drip leaks
Oct 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Joser
Ok, for the PANDORA BATTERY, you'll be needing
1. A cutter
2. Your PSP SLIM battery (of course)
3. Lead Pencil
the steps:
1. Take out your PSP battery, using the cutter, run the sides of your battery along the lines(where the battery has been joined) starting from the bottom until it opens...just be careful or you might mess the board of your battery.
2. Carefully Prop out the board of the battery
3. then, using the cutter still, carefully cut the golden line (indicated by the small blue circle in the pic)...maybe 15 to20 runs of the cutter will do (that's what i did at least). Just dnt press too hard or you might cut through the whole circuit board ok?
4. Then after cutting the gold line, you're through...just close the battery again and tape it up at the sides (i used packaging tape with mine, heheh...) and you're through with the pandora battery!
*NOTE: you'll know that you're successful making the battery when you put the battery in the PSP and the green LED light automatically turns on but there isn't any display on your PSP's screen. If it doesn't turn on automatically, just try to run a few cuts again on the line on the Batt's circuit board.
Turning the PANDORA Battery into NORMAL Battery:
Now, to turn the battery into normal battery again:
1. Open your modded SLIM battery
2. Using the Lead Pencil (i don't know if it works with other pencils too), remember the line that you've cut on the board of your battery? Run the pencil on the cut to re-connect that gold (or yellow) line.
3. You're done. Close your battery again and secure it (again) with tape...Finis!
Jul 31, 2008 | Sony PlayStation Portable (PSP) Console
Jose
Aw, ok...so, first up, to make the pandora memstick, check this thread
hxxp://www.pspmod.com/forums/psp-hardware-guides/23428-guide-making-pandoras-battery-new-method.html
just start with process 2
(Process #2: Creating the Magic Memory Stick with a bricked psp:(well, of course since your PSP is bricked))
after you've made the pandora memory stick, on to the pandora battery.
now, since your PSP isn't working and you don't have any OTHER PSP(specifically PHAT version) you'll be needing
to hard-mod your battery...how to do this? well, first you'll need a cutter, and of course your SLIM battery...the one that came with your PSP...
first up...you must open the battery...and you'll be doing this by using the cutter...carefully slice through the line at the sides of your SLIM battery...just be careful or you might mess it up inside...
then, after opening it, carefully prop out the circuit board of the battery...see this image
[IMG]http://i279.photobucket.com/albums/kk155/devileye001/enlarged.jpg[/IMG]
then still using the cutter, carefully cut the golden line (indicated by the small blue circle in the pic)...maybe 15 to20 runs of the cutter will do (that's what i did at least). Just dnt press too hard or you might cut through the whole circuit board ok? Then after cutting the gold line, you're through...just close the battery again and tape it up at the sides (i used packaging tape with mine, heheh...) and you're through with the pandora battery!
[IMG]http://i279.photobucket.com/albums/kk155/devileye001/markedforcut2.jpg[/IMG]
now, when you've done making youre magic memstick(or pandora memxtick) and pandora battery, just follow the steps on the link i indicated at the top where it says
"Running the files:
----------------"...and when finished, to make you're battery "normal" again, using a pencil, remember the line that you've cut before on the battery's circuit board? Just run your pencil through a few times to reconnect it and you're done. You should have your PSP running again...
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
