Hi, could you help me connect to default gateway when setting up a router. I tried connecting to http://192.168.2.1 but doesn't work. thanks.
  • 43 Answers
Hello! Try to configure your network card`s IP address to 192.168.2.x (x = 2-255) and make sure the router is reseted to its defaults. To do this go to Control Panel > Network and Sharing > Change adapter settings and then right click on your network card > Properties, highlight IPv4 and click Properties. You just need to enter the IP and the Subnet Mask. After you`re done configuring the router change everything back to defaults.
Posted on Mar 13, 2011
    Problem Solver:
  • 8 Answers
192.168.1.2 may not be your default gateway (your router)
  1. Open a command prompt. Start run, CMD , press return. you should see a black box
  2. type IPCONFIG and press return
  3. Look for Default Gateway. it should be 192.168.x.x
  4. enter those numbers in the browser.
you should be on the same subnet as the router so if for example your default gateway is 192.168.1.254 , your pc should have the ip address of 192.168.1.x where x would be a number from 1 to 253
Also make sure that you connect with the network cable, at least until you have everything configured for the wireless.
Cannot access to router
seems like you know computer commands, so the last effort you can try is to RESET your router by pressing-in the button or hole - depending on your model - for at least 10 seconds .
if it still don't work after that, you have to send-in for repair as it does get crashed inside .
Feb 16, 2013 | Computers & Internet
HI, I'm using the Belkin basic router I have few problems here. I cant open http://router/ for the router setting and http://router/wl_main.html for the network name and security setting. I did try to...
Hi there,Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT
use a wireless connection, use a cable.Open your web browser and type the IP address of the router (by default, the address is
http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left
blank, click Submit.Under Wireless menu. -CLICK on SECURITY -- u will find security KEY
kindly rate this post. thank you
Sep 24, 2011 | Belkin Basic Wireless Router
I have a ZSR4174WE router. The default IP address (192.168.2.1) doesn't work (nor does XXX.1.1). Is there someway to ping the router to get the IP address so I can set it up? I don't want to...
If you're connected to the router, you can find the default IP (called a default gateway) by doing the following:
In Windows: Go to Start>Run... type "cmd" (without quotes) and hit enter
type "ipconfig /all" (again without quotes)
Look for default gateway in your wired/wireless connection (depending on how your connected, could be LAN, WLAN, etc. Might be the only one with IP address). The default gateway is the IP of your router.
In Mac/Unix/Linux: Open a terminal and type "ifconfig" (without quotes), and look for default gateway there.
Jul 25, 2011 | Zonet ZSR4154WE Router
Hi im trying to set up xbox 360 live and have been asked for wpa2 pass phrase can you help?
it will either be a password you have set on the router or it may be written on the bottom of the router on a sticker.
if someone else set up your wireless for you then try this guide.
http://www.2pages.co.uk/wireless.html
May 09, 2011 | Video Game Consoles & Games
Hi, the manual says that i have to enter dslmodem or http://192.168.0.1 but it doesn't work, please help me!!!
Try plugging you computer into the router via a network cable.
It should pick up an IP address.
Open up a cmd window from the run command in the start menu.
Type: ipconfig /all (Press enter)
You should see your ip address which has been assigned to you. Look for the default gateway address.
Enter the gateway address into the browser.
HTTP://{gateway IP address}
Good luck.
Hope this helps
Feb 02, 2011 | Actiontec GT704WG Wireless Router...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
