Question about Panasonic Viera TX-P65V10 65 in. HDTV-Ready Plasma TV
My Panasonic TX-32LMD70A tv has developed an occasional fault. It changes from HDMI input, used for Virgin Media system, to TV input from aeriel, used for Freeview, all on its own. This can happen anything from twice a day up to once in two or three weeks. At first I thought that it was due to the remote sending signals on its own so we now put into a drawer and use the tv buttons but it still happens.
  • 6966 Answers
SOURCE: Panisonic TV all locked up
Any other developments (or lack thereof) after our Live Chat?
Posted on Mar 20, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
  • 8457 Answers
SOURCE: Panasonic th-42px80u screen is completely green
Ur backlight video board begining to have problem.When it complely green or no video picture the backlight video board it dead.
Posted on Dec 10, 2009
  • 1051 Answers
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Posted on Dec 17, 2009
I have a Panasonic tx-40cx680b tv and a Panasonic DMP-BD75EB-K blu ray DVD player. When I play a DVD the screen is green, it's connected via an hdmi lead. Any ideas?
There are multiple HDMI inputs.
2 HDMI (side and bottom)
3 4K HDMI with HDCP 2.2 on the rear
Try connecting your Bluray player to the side or bottom input.
Here is a link to the specs
Dec 14, 2017 | Panasonic Televison & Video
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
How do I connect a Panasonic TX-50A300B (TV) to a Panasonic SC-HTB20 Home Audio System?
The audio system sports both a HDMI input AND an Optical input - one can use either. The TV has both of those as outputs so you truly can use either!
You'll need a HDMI to HDMI cable or an Optical to optical TOSlink cable.
Feb 16, 2015 | Panasonic Audio Players & Recorders
Tx 32lmd70a
See if it supports your tv.
Apr 09, 2014 | Panasonic Televison & Video
Panasonic tx p50u30b Black/Blank screen
Might be a resolution issue. Make sure the resolution in windows for that monitor is set to 1920x1080.
Mar 13, 2014 | Microsoft Windows 7 Ultimate 64bit 1 PC...
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
The provided codes dont work with Panasonic TV
nor do they for the TX-32LMD70A.
Anyone got a solution. I hate two controllers.
Sep 24, 2009 | Audio Players & Recorders
Green playback from DVD on Panasonic Viera tx-32lmd70a
there could be something wrong with the tv's input sockets
Sep 06, 2009 | Televison & Video
Panasonic Viera TX-P65V10 65 in. HDTV-Ready Plasma TV Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
