How to set up spiderbox remote control for tv. panasonic viera.
  • 6 Answers
SOURCE: Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Posted on May 01, 2008
SOURCE: SET UP VIERA LINK PANASONIC PT960
The first question you need to answer would be, "Does your TV support Viera Link?" Most newer Panasonic TVs and other A/V devices support it, but it's hit or miss (usually miss) with other brands. I know Onkyo is one brand that has stepped up and offered Viera Link support on some of its devices, but I'm not sure about others. If your LG brand TV doesn't support Viera Link, you are out of luck and you'll have to rely on seperate remotes for the TV and home theater. If your TV does support Viera Link, the next question would be, "Are you using HDMI to connect the devices?" Viera Link can only communicate over HDMI (not component video, S-video, coaxial, composite, digital optical audio, etc.) If either of the aforementioned questions were answered "no", you can still connect your devices and use them normally, but you won't get the benefit of Viera Link communication between the devices. In that case you will likely have to keep using separate remotes.
Posted on Jan 09, 2009
bernardlunda
  • 318 Answers
SOURCE: Acess Code Remote Panasonic Tv TC-68V86A
panasonic remote control codes are
018,016,007,049,067,074,076.
thanks.
Posted on Apr 02, 2009
SOURCE: trying to find comcast digital code to use their
10250
Posted on Jun 16, 2009
SOURCE: Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Posted on Jul 21, 2009
How do you change an Omega Universal 04 01 control one tv to a Panasonic Viera Plasma TV?
Make it easy on yourself and just get another OEM remote for your set. The model number is on the back of the set and they are not expensive.
eBayeBay
Sep 23, 2017 | Sony Televison & Video
My panasonic tv remote won't work, the tv will work from the buttons on the actual set but the remote doesn't
The remote might be defective. Repalce fresh batteries and check. If it do not help you, buy an other remote
Mar 31, 2012 | Panasonic Televison & Video
How do you remove the self check on a panasonic viera 37 in lcd tv?
Hello:
This procedure will bring up the self test screen and reset the unit to factory settings for you.
First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Oct 10, 2011 | Panasonic Viera TC-37LZ85 LCD TV
Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV by Panasonic
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
Sep 27, 2011 | Panasonic Televison & Video
I am in need of replacement remote control for panasonic lcd tv viera
Try website like Remotes.com to buy an exact to an original remote or very close to it.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
