Question about Dell OptiPlex 755 Motherboard System Board Socket 775 DR845
Delll optiplex 755 desktop - motherboard is dr845 13740. Problem with display. When boot up, no graphics on monitor - same as if monitor not connected. monitor checked ok but pc shows no visuals?
  • 961 Answers
I don't know if you have done anything lately,ie; updates to board, cahnge of cables, etc. but first, try shutting down system, unplug your cable for video, unplug tour tower, plug tower back in and restart. If this doesn't work. You may want to try a system restore back to when you had a picture. Try this and let me know if this worked by adding comment or reply at the end of solution.
Dave
Posted on Mar 13, 2011
It is dell optiplex 755 ,when i on my pc it freeze after a certain seconds & not display to the monitor.
Do you have a good working monitor that you can troubleshoot with? I would make sure the monitor isn't going bad first. Then if you're still having the same issue, try re-booting in safe mode and run a virus scan.
Oct 23, 2013 | Dell Optiplex Gx755 Core 2 Duo 2.5ghz 4gb...
How to reset dell optiplex 755 motherboard
Press and hold the F2 key while booting. In Bios, return everything to the factory defaults. This should do it.
Jan 27, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
Will ATI Radeon x1900 run on my Dell Optiplex 755?
Looking at the specifications for the Optiplex 755 line I'm seeing the highest power supply is in the minitower version at 305W. I can't find a document specifying the power requirements for the Radeon x1900, but most benchmark power consumption tests show the system pulls around 280 - 300W with that card installed.
The problem is either your specific Optiplex 755 configuration can't support the power requirements, I don't know if you have the MiniTower, Desktop Tower, Small Form Factor or Ultra Small Form Factor version of the sytem or the card is itself is bad.
Jul 06, 2012 | Dell Optiplex 755 Desktop Intel Celeron...
Non display for DELL GX 110PC Desktop
Either your monitor is bad or the video card inside the computer is bad. To isolate the problem try a different monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker. If the borrowed monitor works, then your original monitor is bad. If the Borrowed monitor does not work, then the video card inside your computer is bad.
May 11, 2012 | Dell OptiPlex GX110 PC Desktop
I have dell optiplex 755 desktop with lcd monitor.everything is all right but monitor starts for 2 seconds and then turns off help me to solve this problen
If is possible we need to establish if the monitor is defective or not. Please connect to a different monitor/LCD TVscreen or just unplug the monitors data cable from the back of the computer powered it up and check if is giving you a message on the screen as "No signal detected". It will tell you that the monitor is fine and is a problem with your Dell computer.
Jun 29, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
I had dell optiples 755 working fine, one day i
Do you mean your motherboard optiplex 755 not working?
If you mean it, and you have to do troubleshooting and found that the motherboard does not work, it is clear your motherboard problem.If you want to fix it you must change the motherboard to another (new)Your have to make sure that you change the motherboard that can support all the hardware on your computer, especially processor, ide slots, SATA, display card (if using) and ram your.If you choose a motherboard that can support all existing hardware on your computer, your computer should be fully functional.
I hope the tips provided to be helpful,
thank you
Jun 30, 2010 | Intel Desktop Board D845WN Motherboard
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
Dell display monitor flashing green light
ple.... check the ram & cables..... after boot in system
Feb 17, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Dell OptiPlex 755 Motherboard System Board Socket 775  DR845 Logo
281 people viewed this question
Alun Cox
