Question about Maytag Refrigerators
Msd2657heb------once every month my frig and freezer stops cooling the frig is on but not cooling---i unplug frig wait 5 minutes then it starts cooling again-all most like it is in a defrost mode that never comes out of sleep mode
  • Maytag Master
  • 19,396 Answers
Hi.
There is need to test the defrost system and the electronics. If the fridge restarts in five minutes, then that is not enough to defrost. Problem may be electronic temperature control. Compressor start capacitor is also worth a look.
Let me know if you want more help on this.
Regards.
Ginko.
Posted on Mar 13, 2011
Freezing compartment stopped operating. Heard motor struggling, then stopped. Frost had gathered at the back wall of the freezer to over 1/2 inch thick. Refrigerator side also gave out cooling. Cleaned...
Hi, What you are having is a defrost problem. You will need a defrost timer or on newer models the control board, also the defrost heater and the termination thermostat. You will need your complete make and model number to get the parts from a local supply house. You will need to unplug the machine. The back wall of the freezer needs to be removed. Use a blow dryer to get rid of ice buildup. Install parts. Timer is probably in the frig compartment or the board on newer models on back of frig. Hope this helps
Jan 18, 2011 | GE Refrigerators
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
My frig was getting the drinks too cold now it is not running.
If its the 2175 then check the display. What is it telling you. Blank?If so unplug your unit wait 5 minutes then plug it back in. If its showing er then you need to call for service. If it shows -- then it needs to be reprogrammed.
Oct 05, 2009 | U-Line ?chelon 2175RB-00
We noticed the same error ER FF on our display this morning. And the fan was making the same loud-troubled noise.So far I unloaded the ice from the ice maker and turned off the icemaker. The noise stopped,...
If you turned off the ice maker, I suggest you unplug the ice maker connection cord so the frig system is not compromised by any default in the ice maker. Next, unplug the frig from the electric receptacle and wait 5 minutes, then re plug. This many times will allow the control circuit to reset itself and the failure/error codes will usually diappear (if nothing else is wrong).
Note: any time you disconnect power to a frig or air conditioner, always wait 3-5 minutes before restoring power to give the compressor time to settle before forcing it to start again; this makes a big difference some times. Good Luck, Macgivor.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frig and feezer stopped working
It sounds like the overload and relay on the compressor.If the problem isn't that then you need a compressor.
Eeggman
Nov 07, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
167 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
