Question about Acer Aspire 1360 Notebook
Hi i have a acer aspire 1360 and would like to know how to take it back to factory setting
5 Suggested Answers
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
  • 1481 Answers
SOURCE: Bios laptop Acer Aspire 1360 is empty / broken after wrong flash
how come ur BIOS is empty....
did u FLASH ur BIOS with any firmware update....
Posted on Dec 20, 2009
gauravkumar6
  • 560 Answers
SOURCE: restore factory settings to acer aspire laptop
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at
http://www.vtechsquad.com/acer-support/
Posted on Sep 24, 2012
Problem VGA Acer Aspire 1360
The only other suggestion is contact Acer customer and technical support to see if there is a resolution to your problem.
Mar 15, 2012 | Acer Aspire 1360 Notebook
I needed to re-install OS, etc on my Aspire 1360 and used the system disk and recovery disks. When I inserted the system disk for the second time, as prompted, all I got was four single bleeps at around...
Hi
please try pressing the ALT+f10 ON STARTUP
this may take you into the factory restore
if it asks for a password and you have not set one then the default is normally 000000 6 zero,s
then follow on screen instructions
if you have the option to save any files or pictures before you do this please do so if you need any saved as you will loose them if you do a complete factory restore
many thanks
Jul 18, 2011 | Acer Aspire 1360 Notebook
Hi Folks. After formating my Acer Aspire 1360, my Cd/DVD Drive don't apear anymore on my computer. Solutions ??
Yes.. Hello. You are having a Media Software Issue that can be solved by going to your computer Manufacturer's Support Website and Downloading/Installing any/all Updates for your Model. Here is the link to get you where you need to go, ok? :)
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Jul 13, 2010 | Acer Aspire 1360 Notebook
Dec 20, 2009 | Acer Aspire 1360 Notebook
Can I install windows 98 on my acer aspire 1360? where do I get the drivers from?
Download the drivers from the Acer WEB site Make sure you select the model of your laptop and the Win98 version of the drivers Use this link to get to the Acer support: -
http://www.acersupport.com/notebook/index.html
Nov 21, 2009 | Acer Aspire 1360 Notebook
Hi i removed my hard drive out of my acer aspire 1360 laptop now nothin its blank its starts up but its like brain ded
yes you have to restart yor system again and make sure it boot from the hard drive. what the system need to run on is in the hard drive
Oct 27, 2009 | Acer Aspire 1360 Notebook
Acer aspire 1360
Offhand, it all depends on what other indicators or things that could be determined. Pls try:
  • determine if there is a beeping sound when you boot the laptop;
  • other than the power and charge indicators, any other lights? blinking perhaps?
  • after sufficient time that the unit has powered up, does pressing on the caps lock makes one of the led light up or close?
  • could you try re-seating the memory modules at the bottom behind a panel/lid?
  • could you try hooking it up to an external monitor and trying?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 06, 2008 | Acer Aspire 1360 Notebook
Laptop drive
dear sie
computer acer aspire 1360 pc dvd drive dease not book
dvd driver stop working c drive was over laoded and the computer whent in to disk clean and deletelte the driver for the dvd rom i can no longer play cd dvd or use the crw or dvd RW ASPIRE 1360 2.8GHZ
PLEASE CAN YUO HELP LOST THE DISK THAT CAM WITH THE MACINE
YUORs garyfifiled@talktalk .net
Jul 28, 2008 | Acer Aspire 1360 Notebook
Acer aspire 1360
No restore patition on the Acer. The download is the same in any computer, desktop or latop. Install XP and download the drivers from Acer, that simple.
Jul 22, 2008 | Acer Aspire 1360 Notebook
Acer aspire 1360
If the original hard drive was replaced in the laptop the cd that came with it will not work.
Mar 30, 2008 | Acer Aspire 1360 Notebook
Acer Aspire 1360 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
