Question about Zanussi Washing Machines
Dear sir my zannussi washing machine is not enptying and it makes a grinding noise im not sure if it might be the pump please advise thank you for your time miss peacock
  • mandypeacock Mar 13, 2011
    what is the easy way to get to the pump miss peacock
  • Zanussi Master
  • 1,527 Answers
Hello, you may have somethink jammed in the pump like a coin that hope it helps
regards
shaun
Posted on Mar 13, 2011
Testimonial: "yes thank you very much great help and advise miss peacock"
  • shaun taylor Mar 13, 2011
    the easiest way if from underneath the washer you will 2 people to do this tip it on it's side slight and and reach from underneath make sure the power off
    shaun
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Grinding washing machine agitator
more than likely the pump is the part that is making the noise. You can verify this by leaning the machine back where you can see the pulleys, your pump will be the one in the back. Remove the belt and each pulley should turn smoothly. The part number for the pump is 35-6780
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | Maytag Washing Machines
Washer won't pump out water makes a grinding noise when turned on
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 13, 2010 | Washing Machines
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag quiet series 300 model mdb5601aws making noise
sounds like the macerator is bent out of shape from something going through the pump. Get a impeller kit and replace all the parts and you should lose the grinding noise. I can look up the part number if you want
Nov 25, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Roper washer not draining
okay you say coupler was broken, make sure coupler is on properly, and make sure your pump is clear of debri, sounds like you washed something heavy, make sure your pump is also clear
Apr 03, 2008 | Roper RAX7244KQ Top Load Washer
Indesit W11 making grinding noise
I think you have a drumbearing problem.:)
Dec 30, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
