I have located the filter but whilst I can turn the plastic 'screw' I cannot get it to come out! Is there a special knack?
    Brigadier General:
  • 6,277 Answers
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
There could be some object like a tooth pick or similar if it will not come out. You MAY have to take a chance and force it finally ;-0)
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Posted on Mar 13, 2011
Where to find oil filter
It probably is located under a plastic cap with a hex nut on it. This cap is located on the engine near the radiator. The filter has no metal casing. Your engine is the metal casing. You need to purchase a special socket at a auto parts store to remove the cap. Make note of how the filter position is so that you place the new filter back in properly and not upside down. Place a new o ring on the plastic cap with a small amount of oil. Screw the cap back on by hand as far as you can to prevent the plastic threads from stripping. Then use the socket with ratchet to tighten. Do not over tighten the cap.
May 31, 2014 | 2006 Hyundai Grandeur 3.3
Location of oil filter in Skoda Octavia 2006 1.9 diesel
Octavia (a4 ) remove top engine cover the engine oil filter is at front cover, big black plastic cover remove with special tool the oil filter can be remove and replace with plastic ring
Nov 21, 2013 | 2006 Skoda Octavia 1.9
How to replace pollen filter on Honda accord type v year 2000
The two filters are located below the glove compartment. In order to reach it you need to pry out the lower center console, where the lighter socket is located. This will reveal a couple of hidden screws that hold the plastic underdash right below the glove box. Pry out this plastic trim piece.This in turn will reveal a structural beam that blocks access to both filters, it has only 4 screws. The filter themselves have no screws, just pull them out.
Jun 15, 2011 | 2000 Honda Accord
The 2007 Tundra 5.7l engine doesn't have a spin on filter - it uses a replaceable paper cartridge within a permanent housing. Located under the skid plate on the front-left portion of the engine, the oil filter unit has two coolant hoses, a black plastic screw-in housing, and a large, metal, round screw with a 1/2" square fitting in the middle of it. The cartridge-type oil filter is in the housing.
If equipped with a skid plate, access is accomplished by removing the 5 skid plate bolts, allowing the plate to swing down on integrated hangars (with the front plastic bumper skirt still attached). To completely remove the skid plate, three small screws holding it to the front plastic bumper skirt must also be removed.
Toyotafilter kits contain a new filter cartridge, a plastic drain plug, and two O-rings. The drain plug is used to drain residual oil from the filter unit prior to removing the plastic screw-in housing. After removing the large, metal, round screw with a 1/2" square fitting in the middle of it, the plug simply snaps into the bottom of the plastic housing. The smaller of the two new O-rings replaces the existing O-ring on the screw.
Once drained, the plastic screw-in filter housing is removed using a filter wrench (Toyota special service tool). The larger of the two new O-rings replaces the existing O-ring on the screw-in housing. VERY CLOSE ATTENTION must be paid in placing the new O-ring - failure to properly seat the new O-ring could result in a massive oil leak! The filter itself is currently only available from Toyota.
Aug 15, 2010 | 2007 Toyota Tundra
How to change fuel filter on 2000 Chevrolet Venture van
your fuel filter should be located below the vehicle on the left side. Most Chilton books cover this procedure. The fittings if not too rusted should allow you to release the fuel line from each end. Many newer vehicles have plastic sleeves that usually require a special removal tool to get them out. I just use a small scribe and flat tip screw driver when tool is available. Most auto parts stores have the tool if needed. Hope this helped. Happy 4th of July
Jun 22, 2010 | 2004 Chevrolet Venture Passanger
Location of oil filter on a 2007 pontiac g6
Oil filter location for a 2007 Pontiac G6. First open and lift the front hood of car. Its some what right from center on the engine about 9 inches from the radiator. All you will see is a black cap with black plastic nut in the center. You will have to buy a special tool to attach to your socket wrench to remove the cap. Turn it counter clockwise to remove it. Inside is a filter attached to a plastic part and rubber o - ring. The filter is NOT enclosed in a metal casing. Remember how it is positioned as you take it out. Pull off the old filter. Remove the old o - ring. Place new o - ring in place. Place new filter on plastic part and place it back inside the engine. Make sure it is placed in the same way it came out. Screw on plastic cap by hand most of the way. The tighten with special tool and socket wrench clockwise, but not too tight. This is now complete. Now you can drain out the old oil from the oil pan underneath the car. Remove hex screw with long wrench for more leverage. One to 2 hours later place hex screw back in by hand and tighten with wrench. Now add about 4 1/2 quarts of 5W30 oil only. Check oil level on dip stick. Add more oil if necessary. Job complete!!!
Mar 22, 2009 | 2007 Pontiac G6 GT Convertible
Where is the air filter
    The air filter is located in the large black plastic box that is on top of the engine. The warranty suggests replacing it every 50K miles.
    To change the air Filter on an HHR:
    It will take some time, so be patient.
    1. Disconnect the air intake hose to the filter box. It is at the left rear of the box as you look at it from the front of the car.
    2. Disconnect the MAP sensor wiring.
    3. Disconnect the coupling to the engine intake.
    4. The filter box is help in place by two ball and socket type retainers located on the back corners. Grasp the box and lift up firmly to lift it free,
    5. Turn the assembly upside down. There are seven torx screws securing the cover of the filter. Remove them and replace the filter.
    6. Reverse the process to re-install the filter box.
Feb 03, 2009 | 2007 Chevrolet HHR Special Edition
Need to replace door gasket
Remove the top cover by removing the 2 screws in the back.
Remove the dispenser drawer completely.
Remove the 2 screws on front of the panel where the dispenser drawer was removed.
Remove the screw on the right side behind the front panel.
Disconnect the wire harness behind the panel.
Starting on the dispenser side with your finger, pry forward the top of the control panel until it unsnaps.  Continue this all the way to the right and remove the control panel.
Go to the bottom filter door and remove the door.  Unscrew the one screw below the filter cap.  Remove the plastic insert covering around the filter cap.
Locate a small screw at the very bottom of the frame just below the filter cap and remove.  Sometimes there may be 2 but usually there is only one.
Open the door and locate the spring clamp usually located at the bottom of the door seal.  Remove the spring clamp.  This will loosen the front of the door gasket for removal from the frame.
On the right of the door gasket is the door latch assembly.  Unscrew the 2 screws and set the latch hanging by the wire harness.
Remove the 4 or 5 top screws holding the front panel assembly.  Once they are removed, the front panel will lift up and out.
NOTE!!!  THIS JOB REQUIRES 2 SPECIAL TOOLS FROM LG TO REMOVE THE SPRING CLAMPS ESPECIALLY THE REAR CLAMP.  THE SPRINGS ARE SET VERY TIGHT SO IT IS NOT EASY TO REASSEMBLY WITHOUT THE SPECIAL TOOLS.
Sep 23, 2008 | LG WM1814CW Front Load Washer
How do i change the filter in my westinghouse virtuoso fridge model rs645
Turn power off this avoids water solinoid valve opening.
Locate the filter housing righthand side under master mind control panel on topshelf next.
Remove light cover by pushing bottom rear up and gently pullout.
Unscrew filter cover looks like upside down juicer.There should have been a special white plastic spanner which came with the refrigerator.
Pull filter element down.
Install new element by firmly pushing up.
Screw filter cover in gently don't over tighten.
Turn power on and operate water dispenser to remove air and check for leaks
Apr 17, 2008 | Refrigerators
Removing the plastic top service plate
if the motor is running and the blade is not turning here is a rubber coupling that has probably broken.the blender will need to be pulled apart and that part will need to be replaced . it is designed to absorb sudden shocks if something hard is hit and has broken rather than burning out the motor. there are two other torx screws holding the rest of the plastic parts after the switch assy is removed by uncliping it .
Nov 18, 2007 | Bamix Gastro 200 Handheld Blender
Washing Machines Logo
Top Washing Machines Experts
