Question about Dryers
Need to find front door handle in white for Model number MD774KW419 has four clips
  • Dryers Master
  • 1,527 Answers
Hello try this site www.espares.co.uk hope it helps
regards
shaun
Posted on Mar 13, 2011
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle
yes it can be replaced, take photo and model number of machine
order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
Oct 05, 2016 | Hoover AAA160 Front Load Washer
How do you fix a passenger door handle on a Ford Explorer 1999
inside or outside????????. either way remove the door panel. the rest is easy
Apr 24, 2015 | 1999 Ford Explorer
How To Replace The Exterior, Front Door Handle On A 2012 Toyota Camry
It removes just like the older style handles with one exception. You must remove the electrical clip/wire that attaches to it while still in the door. It has 2 black clips top/bottom for the harness, one white clip for the actual connector to come off handle (removes toward center of vehicle. After this is off and of course the part behind the moveable handle then the moveable handle will shift backwards and out while swinging rear away from door.
Dec 27, 2012 | 2012 Toyota Camry
How do I remove a front left panal from a 2001 cadillac.
Hi, to remove the front door panel, remove the plastic surround from the inside door handle. It contains the seat switches and door lock switch. It is held in place by four pressure clips, so you should be able to pull straight out. Remove the wires to the switches. Next remove the window switches by inserting a small, flat screwdriver under the forward end by the window lockout switch. Carefully pry upward. Remove the wires if you want to make removing the panel easier.
The triangular panel on the inside of the rearview mirror will need to be carefully pulled inward but NOT REMOVED. You might be able to do this with just your hand. Remove the white/red marker/courtesy light at the back side of the door panel. A small flat screw driver at the back side should release it. Remove the wire. There are two phillips screws that need to be removed. One is in the opening where the window switch panel was, the other is behind where the red/white light was. After those two are removed, grasp the door pull handle and pull STRAIGHT UP. Don't try to pull inward.
Jan 29, 2011 | 2001 Cadillac DeVille
Whirlpool gold side by side door handle is loose.I can't find the way to tighten. IT appears the screws are underneath the rubber gasket, but I am a little wary of tearing it loose without anew gasket.
Most door handles now are front repairable. I can't tell without the model number which style you have, but most units have an insert in the door handle. You have to pry this insert out, to get to the screws for the handle. Some handles actually clip on to the door by sliding the handle up or down to clip it on or off. Good Luck, Appliance Specialists.
Feb 04, 2010 | Refrigerators
Need a part number
The part number for the door handle on this model dishwasher is either:
W10142998 (STAINLESS)
W10142999 (BLACK)
W10143000 (WHITE)
The handle is listed as item 14 under the "Door and Panel Parts" section at searspartsdirect.com. The part numbers are based on the color, so make sure you use the correct number to get the matching handle for your dishwasher. The kit inlcudes all the mounting hardware as well.
You can check these others sites as well to compare prices:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a 99 mitsubishi eclipse and I'm wondering how to install the door handle
i just did one on passenger door, roll window up, use 1/4" sockets, on door end, by door latch there is a 10mm, level with door handle, take off door panel inside, you'll see the window where its bolted, just behind that dip down shape of the window where it attaches, you'll see another 10mm bolt, take those 2 bolts out, remove the two extension rods, cliped on to handle lever, and lock cylinder, one on handle is white clip, one on cylinder is green clip, flip the snap part of clip away from rod, and slide rod out of clip hole, walla, pull handle out, unclip retainer clip from around slots holding cylinder into handle, and your done, p.s. try to reclip door handle rod into white clip before bolting back in to gain easier access to white clip and rod, green isnt as hard
Jun 30, 2009 | 1999 Mitsubishi Eclipse
Remove door panel on a Ford Van
For a 1999 Ford Econoline 150 (assume the same or very similar), remove triangular plastic cover over mirror assembly by prying straight out, remove plastic door handle cover by prying up from the front side, remove electronic door switches by prying up from back side, remove round plastic cover at bottom rear of door panel. Four screws are now revealed, remove them. Lift door panel straight up, clips are hooks (not snap in). Work door switch assembly out of door panel. Set door panel aside. Reassemble in reverse order.
May 09, 2009 | 2000 Ford Econoline
Fallen driver's side window
probably need a new window regulator. ebay. 93 to 98 should fit.
Section 01-05: Trim, Interior 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. swv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942) .
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel .
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screws from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124) .
  1. Remove the front door trim panel.
Installation
To install, reverse the removal procedure.
Window Regulator, Power Front Door
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Remove the front door window glass (21410) . Refer to the front door window glass removal procedure in this section.
  1. Remove the two front door brace bolts and the front door brace.
  1. Disconnect the front window regulator electric drive electrical connector.
  1. Remove the four front door window glass regulator track bolts.
  1. Remove the three front window regulator electric drive bolts.
  1. Remove the front door window glass regulator track and the front window regulator electric drive (23394) as an assembly through the opening in the front door (20124) .
Installation
  1. Install the front door window glass regulator track and the front window regulator electric drive as an assembly through the opening in the front door .
  1. Install the three front window regulator electric drive bolts. Tighten the front window regulator electric drive bolts securely.
  1. Install the four front door window glass regulator track bolts. Tighten the front door window glass regulator track bolts securely.
Apr 29, 2009 | 1998 Mercury Villager
Front right door window will not go up or down, it is electric. it works, some times, and some times not. it is in the down position. Would like to move to up position. I live in Arizona, I need it up for...
does it act the same whether you use the driver door switch or the passenger door switch? Please rate as fixya if this helps. thanks
here's repair procedure
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
Trim Panel, Front Door, Explorer Hi-Series, Two-Door and Four-Door Removal and Installation
  1. Remove the two screws retaining the front door trim panel (23942) located above the window regulator handle (23342) . Also remove one screw in the upper front portion of front door trim panel .
  1. Remove inside door handle cup (22634) at the window regulator handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator control switch (14529) and outside rear view mirror control (17B676) , use notch located at lower end of outside rear view mirror control using a screwdriver to lift and remove.
  1. Remove outside rear view mirror control from front door trim panel pulling wire harness from inside of front door trim panel .
  1. From bottom of outside rear view mirror control, remove two screws and disconnect connector from switches. NOTE: Do not pull on the front door trim panel to remove clips from the inner panel holes.
  1. At each plastic clip location, pry the front door trim panel away from the door inner panel using the front door trim panel removing tool from Rotunda Moulding Trim Kit 107-00401 or equivalent. NOTE: Pay special attention to the cut-out in the door trim panel for the door handle, so that it clears the handle during removal without breakage.
  1. When wiring and disengagement of trim clips is completed, it is recommended that to remove panel, lift slightly to remove flange at the top of door trim panel from trough in the glass weatherstrip.
  1. Disconnect socket and bulb from illuminated interior lamp (13776) before total removal of front door trim panel. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the front door trim panel to the front door trim panel , firmly loading clips into slots provided on front door trim panel .
    Trim Panel, Front Door, Explorer Hi-Series Four-Door
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Apr 20, 2009 | 1994 Ford Explorer Limited
Dryers Logo
29 people viewed this question
Top Dryers Experts
