Question about ASUS M4A88TM Motherboard and AMD HDT90ZFBRBOX Phenom II 1090T Black Edition Six Core Processor Bund
Hello there, I have a problem I don't know how to resolve. My motherboard is M4A88T-M USB 2.0 with Phenom II X6 1090T Black Ed. Today, while my pc was in stand by mode there was a power outage but was it was connected to a ups. So I tried to get into windows to shut it down properly. But for some reason I couldn't get out of sleep mode. So I had no choice but to turn off the ups. Later when I try booting nothing happens. The only sign of life that my pc shows is that the motherboards stand by power light is up. That's it. It's just 3 weeks since I bought this pc. Could anyone tell me what's wrong? Will be much grateful to any reply, Thanking you, Timothy
  • timothyroysi Mar 13, 2011
    Hey junkydave, thank you for the reply! Nothing in the pc is working. None of the fans are spinning only that stand by led situated on the motherboard is glowing. So I can't try out your solution. As even the psu's fan is not spinning, could that be that's causing the problem? Ask me for any other details if it's required.
    T.
    Thank you for replying don! The system is unresponsive when I try to boot it. Nothing happens, no spinning fans too. So I can't try out your solution. Since the psu's fan's not spinning as well could it be the malfunctioning unit?
    L
  • 961 Answers
If your systemwill start in "safe mode" you can try a a'system retstore" back to when it was working.
Let me know if this helps through "add a comment" at end of soloution.
Dave
Posted on Mar 13, 2011
  • 20 more comments
  • David Petry Mar 13, 2011
    Whos system is the board in?
    I'm sorry, but what do you mean by that? I couldn't understand you.
    Is it Dell, Gateway, etc.?
    I got it assembled. I purchased the parts separately and had the store itself put it together. And if any parts fails I have to take it to the manufacturers respective service center myself. So I'm doing my best to solve it myself. If it's possible.
    If nothing else I would tryhttp://support.asus.com
    There should be support there but there is also a forum where someone may be able to help you. At least one of their boards, I'm not sure about yours has a built in surge protector that may have switched your power supply. How to get it back is the qusetion
    Dave
    I'll look into it about this surge protection switch. That may be the case too, considering that I'm living in a place were there is voltage fluctuation. And thanks for the link. I am checking it now.
    I was looking into the manual of my board and I came across this:
    Restore on AC Power Loss [Power Off]
    When this item set to [Power Off], the system goes into off state after an AC power loss.
    When this item set to [Power On], the system goes on after an AC power loss.
    Configuration options: [Power Off] [Power On] [Last State]
    I don't remember any such option. And the description is a bit ambiguous. If the "power off" option is what I think it means, my pc will not start after an ac power loss? And I don't remember setting any such option.
    Do you have the manual now?
    Yes, I do.
    Looking further into your board, I have looked a couple of different places, it probably does have taht feature. I was just looking to download the manul but with no luck so far
    Hey thank you!
    Looking further into the manual I found this:
    Anti Surge Support [Enabled]
    Enables or disables the Anti Surge function. Configuration options: [Enabled] [Disabled]
    I don't know what it does. If a surge did occur.
    And here's a link to the manual:
    http://www.cizgi.com.tr/resource/vfiles/...
    Anything new? I've been tied up with something else so had to take a break. I couldn't get your link to work so I'll try from internet again.
    Dave
  • timothyroysi Mar 14, 2011
    Sorry couldn't reply earlier, Dave. I tried google for diff possibilities and I somehow have a feeling it's the psu. Having no other way to find out the best thing, I feel I should do is get a replacement for the psu. Hopefully something stirs after that!
  • David Petry Mar 14, 2011
    I looked a little bit further into it, I just acn't get that manual, but are you sure your getting 110v in? Is it hooked to an external surge protector or, check voltage at outlet.
    Dave
    AMD has support also. It takes them time to grt back and they might not answer question you want first time but, you could try them.
    I'll try amd too. And I live in India so that 220v for me not 110. It's hooked to a ups
    From what I read the boards with the surge protection are specifically for India because of power surges.
    So if that's the case what do I do? I'm going though amd's website. And trawling through the web I came across something painful. The psu I went for is apparently a company run by scoundrels. I'm talking about huntkey whose psu's apparnetly explode when used at its max wattage. I really am the biggest idiot for falling for this company!
  • timothyroysi Mar 19, 2011
    Hey there, it was a faulty psu. I had it replaced. I hope this one will last. Thanks a lot for the support that you gave me.
    -Tim.
  • David Petry Mar 19, 2011
    Glad to hear you got it resolved and good luck with it.
    Dave
    Thank you!
  • ASUS Master
  • 27,725 Answers
Your computer might have protectected itself from power loss/data loss
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
don
  • 12 more comments
  • Brian Sullivan
    Brian Sullivan Mar 13, 2011
    Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
    hope this will help
    That's what I'm planning to do. Get a replacement first. Don't think I'll have time to do it before saturday. So pc action till then!
    Thank you very much for replying, bronk50. Really grateful.
  • Brian Sullivan
    Brian Sullivan Mar 14, 2011
    most power supply units will fit you can get a larger wattage output eg: heavy duty if you have added any more devices to your computer more RAM,a larger hard drive,more cd/dvd drives these added will put a greater need for wattage output on the PSU
    you should check all the electrical connections before you make a decision and make sure they are the same as as the ones that you will need to run your computer also
    check the measurements inside the frame to make absolutely sure it will fit
    What do you mean by checking the electrical connection? With some testers? Like that voltmeters or so?
    I went to this website,http://www.extreme.outervision.com/PSUEn... and got a recommended power supply of 400 for my config and a similar one at asus's site suggested something similar. So won't getting the replacement with an exact model thru warranty work out?
  • Brian Sullivan
    if you can get another on warranty it should be the same as the one you had in it but if you have added any extras such as moe RAM,another cd/dvd or a slave drive it will put a greater strain on the PSU also what i was referring to by checking the lead ends was to make sure that they are the same as the ones you have or you test the electrical extensions using a multimeter to make sure there is power
    I don't know where to go for a multimeter. Nor do I know how to use one. So if the psu, supposing, I'll have to get a powerful on all on my own money right? Or will they let me pay the difference and get me a one with higher wattage?
  • Brian Sullivan
    dont worry about the multimeter im not sure if they will let you pay the difference but all you can do is ask im sure they will listen to your request and hopefully supply you with one with greater wattage
    Hahaha! I'll do that. Hope they listen!
  • Brian Sullivan
    dont worry about the multimeter . Im not sure if they will let you pay the diference for another PSU with greater wattage all you can do is ask im sure they will listen to your request and hopefully supply you with one
  • Brian Sullivan
    dont forget to put your negotiating boots on before you go to get your PSU
  • timothyroysi Mar 15, 2011
    Now we have a problem. I could be described as the worst negotiator in town. Still, I'll try!
  • Brian Sullivan
    Brian Sullivan Mar 15, 2011
    just tell them it was not adequate for your computers hardware and if you need to add more ram or a bigger hard drive it will need more wattage
    Hey there, it was the psu after all. No, I had no luck getting a bigger one but I hope this one will last. Thanks a lot for the support!
    -Tim
  • Brian Sullivan
    Brian Sullivan Mar 19, 2011
    only glad i could help you
How do I upgrade an AMD Phenom II x3 710
I suspect you mean the Motherboard that has the AMD Phenom II x3 710.
If so then find specifications on that motherboard to see what better, faster? CPU is compatible with it.
4th Core is Disabled by AMD and you need to know how to enable it?
Maybe this can help.
Overclocking Phenom II x3 710 2 6GHz to 3 5GHz unlocking 4th core
Hope it helps
Oct 11, 2014 | AMD Computers & Internet
Is the Am3+ socket also possible for sapphire AM3RS890G2?
am3+ socket is what the socket is listed on the motherboard, so if you have a CPU that fits only AM3+, the CPU wont fit it unless directed by the CPU manufacture seeing that AM3+ is for AMD processors only if you have a older AM3 CPU it might fit the AM3+ motherboard if listed, this paticular model only lists AM3 and fits Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6
Aug 10, 2014 | Sapphire Technology PC-AM3RS890G2 Desktop...
I am using maya software when ever i am going to render my pc get shut down. what to do in
You didn't post the Make, Model of Computer. Perhaps you have to many running processes? Try shutting some unnecessary processes. Take a look at support: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14051440&linkID=9242258
Apr 26, 2013 | AMD PHENOM II 4X Z965 AM3 BLACK ED Phenom...
Will hdz965fbgmbox processor work with ami po1-ao mobo
AMI is American Megatrends Inc.
A BIOS program company. (Basic Input/Output System)
AMI po1-ao is one of AMI's BIOS programs.
Used on a LOT of desktop computers, and consequently several different motherboards.
How about the motherboard manufacturer, and model number; or computer manufacturer, and model number? Model number is on the back of the computer next to the Windows product key; or up on the side of the computer tower.
Post back in a Comment.
Regards,
joecoolvette
Nov 27, 2012 | ATI Amd Amd Phenom II X4 965 Black Ed. -...
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Does anyone know what motherboard is used on the - ASUS Essentio Desktop / AMD Phenom II X6 Processor / 8GB Memory (CG133007) ?
You can just simple use this software to knowing your motherboard is. Its support the latest version of all known motherboards.
Aug 06, 2011 | ASUS Essentio Desktop / AMD Phenom II X6...
I have an asus m4a88t-v motherboard with an AMD phenom II x6 1090T processor that I just built. When I turn it on, it powers up but nothing shows up on the display. There are no beeps from the motherboard...
make sure the battery in mother is good and double check fuse. what it is you have a 3x2gb corsair is over loading your mhz ram get a higher battery for higher performance and see what happpens.
Feb 17, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
I have a EVGA 9800gt Akimbo and my system wont even give the post beep, all it does is everything powers up and the fan on the card sounds like it goes full blast but nothing happens, did I get a bad card?...
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
Try using onboard VGA, install the RAM modules one at a time apon powing up.
Install the Graphics Card in a Friends computer to test if it works.
See my published guide it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
It gives you a better understanding of what you should do to try and get it going.
If you are still experirencing problems it most likely a faulty mainboard, claim warranty support.
Happy Testing and Happy Gaming, For the Win!
Thanking you kindly
damnor01
Jan 07, 2011 | Smith System s EVGA GeForce 9800 GT...
ASUS M4A88TM Motherboard and AMD HDT90ZFBRBOX Phenom II 1090T Black Edition Six Core Processor Bund Logo
235 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
