Question about Hotpoint Washing Machines
Hi! I have an Ariston AML125 and its stuck on the first cycle where it continously tries to load the detergent into the clothes. I have checked the manual and i cant find any errors which would cause this. I have also tried different programs, restarting the machine etc. Do anyone have an idea of what might be wrong?
3 Suggested Answers
SOURCE: indesit W93 washing machine
We have W124, it allmost completed renewed inside. Thanks 3 years warranty and new service engineer, motor was changed and then all problems disappeared.
Posted on May 01, 2007
  • 5 Answers
SOURCE: Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Posted on Feb 07, 2009
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Leaves white deposit on washing
    What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
    Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
    Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
    Apr 06, 2011 | Ariston Technologies Ariston AWD12 Front...
    CLOTHES NOT SPINNING DRY
    you have something stuck in the pump..a sock maybe or some other small article of clothing
    Jan 11, 2009 | Hotpoint -Ariston VVSR1030HWO Top Load...
    Can I connect my AML125 to hot water
    Not advisable if it is a cold fill washer only, as you will then be rinsing in hot water, and this could cause shrinkage of clothing and other adverse effects..
    O/k if it is hot and cold washer.
    Plz rate my solution.
    Thanks.
    Jan 06, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
    Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
    Dryer
    It sounds as if you have the dryer button pressed in before you start the wash! If you don't. it is likely it is stuck in or the switch is shorting out on the back. Unless you are a competent DIYer, find someone who is to check the electrical connections and test whether the switch is working correctly.
    Sep 14, 2008 | Ariston Technologies Ariston AWD12 Front...
    Soap left in clothes
    hope you are using he detergents (high effeciency low suds) also if you have soft water oversudsing can occur even with he ..try reducing amount ..also have been told tide he detergent tends to suds more so may try switching detergent brands try runing washer with no soap no clothes begore next load to flush out any detergent that may remain ..be sure to run washer with bleach no clothes on short cycle peroidically to avoid mold/mildew odors that front loads tend to acquire after a few months use and leave door open if possible between uses..let me know about detergent thanks
    Jul 15, 2008 | Kenmore 44102 Front Load Washer
    Ariston Dishwasher Detergent dispenser
    you have 2 options.replace the timer on the unit or when you start a load wait 10 minutes and put a half cup or a little more of detergent into the water in the dishwasher.
    Jan 05, 2008 | Ariston Technologies LL64WNA Built-in...
    Washing Machines Logo
    20 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
