Question about Samsung Televison & Video
I HAVE A TV DNIE SELFOCUS PROGRESSIVE 100 HZ SRS.THE GREEN COLOR IN VERTICAL DIRECTION IS NOT MATCH WITH ANOTHER COLOR AND HAS A CURVE IN IMMAGES.PLEASE HELP ME.THANKS CHANGIZ
  • Samsung Master
  • 1,527 Answers
Hello it sound like convergance ic are the problem. 2 big chips the sit on a metal frame called heat sink that are located behind the tuner board also there may be some resistor that sit in front of the chips and 2 capacitors at either end these will need to be tested as well hope it helps
regards
shaun
Posted on Mar 13, 2011
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
Red and green vertical lines
Your problem appearing after the TV has 'warmed' up indicates a faulty electronic circuit board/power supply: if not under guarantee, it may not be cost effective to get it repaired.
Apr 06, 2014 | Panasonic Viera TX-L42D25B 107 cm 42" LCD...
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 24, 2011 | Televison & Video
Samsung Dnie, flashing lights then no color!
Turn every thing off then unplug power cord for a good 30 seconds - check all cables and turn back on.
Feb 15, 2010 | Samsung Televison & Video
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
Color valve pic is pink
The back ground of tv is green,so i might guss the problem is mono chromo ic.what do u tell me about color?
May 13, 2008 | Televison & Video
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Televison & Video Logo
357 people viewed this question
Jerry Greenberg
Jerry Greenberg
