Question about Bosch Ovens
I have just bought a Bosch double oven type HBB-DP81-7 ex demo unit. The wiring to the elements have been completely removed (presumably for safety reasons) and I have no way of finding the cables or the person responsible. Can I obtain a wiring diagram so that I may employ a local qualified electrician to fix?
bigg t
  • 640 Answers
SOURCE: blodgett oven
if you only have 3 wires to the element it doesnt matter how there hooked up.
Posted on Aug 11, 2007
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
SOURCE: installation guide - bosch hbn131250b
1. The screws seem to need a small hex screwdriver, but I managed to get my normal electrical screwdriver to fit - they are not too tight.
2. The wiring is straightforward - there is an earth position with no wire from the oven attached, marked with the standard earth sign, that should connect to your yellow/green wire. The other two connectors have either a blue (neutral) or a brown (live) wire attached to them - they should connect to your black (neutral in old money) or red (live) wires
Posted on Jun 20, 2009
Lost my oven wire when I removed broil element
pull unit out then remove back panel cover after unplugging power to unit,it will be accessable from here
Nov 24, 2012 | Thermador C302U Electric Double Oven
Tip
Common heating faults with Bosch HBL 455 Stainless Steel Electric double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 455 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 5052 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5052 Electric Double Oven
Suspected burned out heating element
your "specific" answer is same for all, If your element is "open" then your ohn reading would be infinite,if it is shorted it would be 0 ohm both cases would need replacing. You need to look at the wiring digram for a temperature switch[thermostat] which will be connected in series with the element. All heaters,microwaves ovens,are required to have them They open up when or if oven gets too HOT. The little units cost about $2-3 and can be bought online [e-bay] Go to applianceaid.com/appliance-repair-help.php find your make,model and they will show you the part and how to replace it.Good luck Steve The unit is a protection device always replace it with proper temperture rating.!
Oct 15, 2012 | Bosch Ovens
Fan working but oven not heating,if it is element how do i replace it. Model number BoschHBN9153GB double oven.
It will be the element that needs to be replaced, remove panel at rear inside of oven, you will see the element located there.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Tip
Common heating faults with Bosch HBL 5056 double oven
on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
Tip
Common heating faults with Bosch HBL8750UC double oven
on Jan 19, 2010 | Bosch HBL8750UC Electric Double Oven
Fan oven not heating
its the element not the stat
Mar 10, 2009 | Bosch Ovens
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Tip
Bosch HBN13M250B/01 not heating or fan is not turning, common faults.
For all Free Bosch appliance repair videos visit our VIDEOTUTORIALS
A fan oven that has stopped heating up is probably the mostcommon oven fault that professional engineer is called to. The cause inmost cases is simply a faulty fan oven element. To employ the services of arepair company is going to cost you in the region of £60 - £100 to complete thejob.
With a little time, though and our FREE fan oven element video itshould take less than half an hour to repair, and the element can be purchasedfrom us for as little as £20 ! Why not Save yourself some money and read on
1, If the Bosch fan motor in the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter.
To gain access to the Bosch element you will haveto remove the back plate from inside the oven. Once removed you will see the Boschfan and element, if you look closely at theBosch element you will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but the element is open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your Bosch fan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your oven fan motor is workingyou will see the blade turning fast if it is ok. if the element is heating butthe fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace your Bosch oven thermostat
4, A quite common and easily overlooked answer isif your oven is not working atall ie: no heat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
on Jan 13, 2010 | Bosch HBL 5052 Electric Double Oven
Ovens Logo
607 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
