Question about Audiovox SP11CDP 10-Disc CD Changer
I need help!
I had my battery replaced recently and i need to find out how to reprogram it to run through an un-used fm radio frequency
HI THERE I JUST PURCHASED EUROVOX RADIO WITH 10 CD STACKER FROM EBAY BUT THEY NEVER SUPPLIED ME THE CODE TO ACTIVATE THE UNIT BOUGHT IT OF COMMODORE WRECKER IN SUNSHINE VICTORIA CAN YOU HELP PLEASE
Posted on Feb 28, 2009
LS. How do I reprogram the frequency bandwidth on FM on a theftlock radio?
You are confusing AM channel spacing with FM tuning. Some radios have a switch for selecting 9 KHz or 10 KHz spacing.
Jan 28, 2016 | 2002 Chevrolet Blazer
Toyota-56037 radio (FM/AM) malfunctions..like... the system receives FM signals 76Mhz to 90 Mhz only although there are a lots of channels after 90Mhz. How to reprogram it? Plz help. TAUFIQ
if there is a mode button , press that and there is fm 1 whch is what you have , press again and you get fm 2 press again and you get fm 3
each fm number is a band width so select the band width that has most pf your stations and then auto select on it
if you have the owners hand book , the procedures are in ti for setting the radio
Nov 17, 2015 | Audio Players & Recorders
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
I just got grunding 800 radio,no reception either am,fm ,sw please help me.
This is valid for the Satellit 750 by Eton (current owner of Grundig)
When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range.
If it is used in North Ameraica, you are told not to go through procedure but do it any way.
SYSTEM Code setting
Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display
1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages.
2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America)
The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
Aug 11, 2010 | Grundig Satellit 800 AM/FM/SW Radio
IS THERE A WAY I CAN PLAY IT IN MY CAR IN THE RADIO
Yes, You will need to purchase a device called an FM transmitter, it plugs into the headphone jack and transmits the sound to your FM radio. The transmitter will have station settings, you just find a radio frequency that does not have a station in your area, set the transmitter to that and tune your radio to the same frequency. You can get the transmitters from Walmart electronics dept, Target, Sears, Amazon.com, Radio Shack and most other electronics retailers. The transmitters run about $12-20 and can be battery powered or plug into your car power outlet. Go to google.com and do a search for "MP3 FM transmitter" and you will see what they look like.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | iRiver E100 Digital Media Player
Delphi skyfi won't connect to my fm radio automatically.
The audio plug overrides the FM frequency setting. That way if you use a tape adapter to run the music through it will use that source instead.
A lot of FM channels are getting crowded into a lot of markets out there. The best way to fix the problem is to use a direct FM module. This way your Sirius will override the FM channel whether it is used or not.
Here is a link for one:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1998401&catParentID=7872&scId=7872&oldParentID=7872
they are very easy to install.
Mar 17, 2009 | Delphi SKYFi XM Radio Receiver
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
Audiovox SP11CDP 10-Disc CD Changer Logo
207 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
