Question about Apple iPhone 3G
Camera not saves the pics and direct going back to home screen
    Problem Solver:
  • 10 Answers
I recommend to make software restore with iTunes.
NB! Make restore before backup.
Posted on Mar 14, 2011
Can I reverse camera shots from front to back?
Access the camera settings within the screen--depending on your tablet and Android version--look for the directional camera icon, typically a camera icon with a curved arrow signalling directional option.
Mar 06, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Blank LCD screen taking pics
Try to reset the camera.
RESET
: Find the * QUAL and +/- * buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks and everything is back to normal.
Sep 01, 2008 | Nikon D200 Digital Camera with 18-200mm...
I was making a video of all my pics a while back and saved it to a dvd-r. I forgot all about it and ran across it yesterday. I now want to get those pics off of that file which is a wmv file. Do I need to...
If all you have now is the video (wmv) file and no pictures saved anywhere there isn't a direct way to get them back to their original form. The simplest solution that requires no extra software may work okay, depending on how much the quality of the photos matters.
What you need:
Open up the Paint program (Start Menu > Search bar > type in 'Paint' and open the file it finds)
Run the video file (fullscreen)
You can open the video and for every picture you have pause the video and then hit the 'Prt Scrn' (print screen) key once; usually located towards the upper right of the keyboard.
Once you have done that pull up the Paint program and either press Ctrl+V or click the "Paste" icon at the far left side of the toolbar. If that worked you should have a copy of the picture in paint now. If you do then save the image.
Now just go back to the video and resume play until you get to the next picture, pause it, and repeat the above steps until you have all the photos saved.
There are screen capture programs that would simplify this process, but I don't have any to suggest offhand except FRAPS which costs about $30 to purchase and is primarily used for video recording.
Aug 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Do not know the process of deleting pictures from camera!
The delete button deletes images stored on the memory. It is located on the back of the camera and looks like a little garbage can. It is the middle button going vertically down on the right side of the display screen. First hit the button below it that looks like a printer. It will display a picture. Then use the left/right buttons down where the OK button is in the middle. This will take you backwards or forwards in your photos. Next push the delete button it will ask if you want to delete yes or no, use the left/right buttons again to choose yes or no. Then push OK in the middle and it will delete your pic if you chose yes or save it if you chose no.
You can also go in on Play mode [under the /- button where garbage can is] and press the Menu button...go left or right until you find DELETE screen and then follow directions from there. All these directions are on your CD that came with the camera.
Hope this helps. MAKE SURE you have downloaded whatever you want to keep on your computer before deleting.
cls
Oct 18, 2010 | Samsung Digimax D53 Digital Camera
1)I cant save pics from camera roll or media files in a seperate folder in xperia x10.. i can create a new folder on the main screen but then how to add the pics or files in the newly created...
1) for this go to the setting of you camera hen go to save images in.. and then select your folder and save it..as do this same for videos.. 2)First select multiple images using marking them one bye one then go to option then go to send then via Bluetooth ...it will work... but you can't send a folder...
Oct 18, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Camera says its saving all pics to the internal memory. I want to switch it back to memory card
With no card in the camera, go into the menu and find "format"....follow the on-screen instructions. Then, you can insert your card and it should work properly.
Aug 07, 2010 | Fuji FinePix Z10fd Digital Camera
When the camera is turned there is no isplay on
Sounds like you yanked out the cord without using the "safely remove hardware" icon at the bottom right of your screen. Now your camera is corrupted (probably the card,too). To get back to life as you knew it: 1. Go out and buy a card reader and use it to download the pics from your card. 2. With no card in the camera, remove the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. 3. Go into the menu and find "format"...follow the on-screen directions. Now, enjoy your camera.
Feb 02, 2010 | Fuji FinePix S2000hd Digital Camera
Will not read memory card says full
You need to switch the camera over to saving pics directly onto the SD card.
1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note if the SD card isn't in the camera or is unreadable the camera will automaticly go back to saving on the internal memory.
If helpful pls. rate me or/and give me a recommendation. TXS
Dec 03, 2009 | Kodak EasyShare C330 Digital Camera
Can t see pic saved on the card on the lcd screen
Did you accidentallypress the DISP button on the back of the camera? Try pressing it to see if it turns the display back on.
Jan 25, 2009 | Canon PowerShot S2 IS Digital Camera
Saved pics
Hi,if dont have any very important picture stored in camera you may reformat it all protect picture will erase , the camera sim has no more vacant its full you connot store picture anymore best solution is to reformat it.press menu , press setup,navigate down select format. then okey.
Dec 11, 2007 | Cobra Digital DC6550 Digital Camera
Apple iPhone 3G Logo
16 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
