Question about Freezers
Eurolec fridge freezer RF010 ---spares? need a
Eurolec fridge freezer RF010 ---spares? need a thermastat has eurolec gone out of business ?
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
We bought a Woods all fridge and upright freezer pair
Do you know what parts are needed? Some are available and some are not.
Apr 24, 2010 | Woods Upright Freezer MU07W
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
The fridge(in my fridge/freezer has stopped
http://www.google.com/search?hl=en&rls=com.microsoft%3Aen-us&q=Cheltenham&as_q=refridgerator+repair+service&btnG=Search%C2%A0within%C2%A0results
go to this page on Google and look at what is available in your area, there are several businesses that do that kind of work.
Good Luck
Aug 07, 2009 | Freezers
I own this 2.6 cu.ft. chest freezer GEV70 and the pilot wont stay lit. think i need a thermostat or thermocouple thing. where can i find one? please hurry as my tiny servel in the fridge freezer will not...
It seems the place that I purchased my GEV70 (Explorer LLC in San Diego) has gone out of business and I need someone to fix my GEV70 that won't lite any more. Were you able to find someone to work on yours? If so, who?
Thanks
Jul 08, 2009 | Explorer Appliances 2.6 cu. ft. / 74 liter...
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
Beko fridge freezer
Is it froze up? maybe it needs defrosted.
Jan 19, 2008 | Freezers
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
66 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
