Question about Bosch Washing Machines
The washing machine has stopped working whilst full of water. How do I empty it without flooding the kitchen? Please.
    Brigadier General:
  • 6,277 Answers
2 ways! If yours is similar to our Bosch, behind the front lower panel is access to the filter (see notes below). There is also an easily accessible 'loose' pipe with a stopper which you can use there.
Otherwise follow the notes below which MAY cure the 'stopping washer' at the same time ;-0)
So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
__________________
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Testimonial: "I emptied the machine and cleaned the filter. I found a small plastic peg - (from the top of a Biro) - machine appears to be working now - Thanks"
Door will not open if machine not emptied immediately cycle ends
This is an anti-flood protection, since water would flood the kitchen if you could open the door. If the machine shuts down for some fault and leaves the drum with water in, then it is advisable to drain the drum down via the small hose at the front of the machine. Simply remove the plug and empty into a large container until the drum is empty. You can then start to work out why the cycle ceased prematurely.
Mar 08, 2015 | Miele Washing Machines
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Why wont my machine empty out..
The problem you are having is the pressure switch, also called the water level switch.Without a model # its hard to give any real direction for repair or any part #.
May 06, 2012 | Hotpoint Washing Machines
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
What does error code 2 means on proline washing machine
With mine when i had the error 2 code, it was money in the filter.
Switch machine off
I had to get a baking tray and a towel, i pu tthe baking tray under the filter corner, then slowly unscrew the filter (bottom right front of machine) then let water slowy trickle into baking tray and then empty, and repeat until water stops took about 20 mins. Of course you could do it quicker if you want to flood your kitchen. :)
Then emptied the filter, then ran spin only until end. worked fine after this.
Apr 11, 2011 | Washing Machines
It is full of water and will not drain or spin, how can i empty it without it flooding the kitchen?
hello,Take the hose out of the drain hole and place it as low as possible with a bowl or bucket underneath..It should then drain hope it helps
regards
shaun
Jan 03, 2011 | Hotpoint First Edition FEW12 Front Load...
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
372 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
