Question about Casio Watches
Setting time on pathfinder - Casio Watches
Set casio pathfinder watch
try this site:
http://www.ehow.com/how_5214673_operate-casio-pathfinder-watch.html
Nov 12, 2014 | Casio Pathfinder PAG80-1V Watch
How to set time casio paw 1100 1v
On pages 2 and 3 of the manual (module 3043) you can find the instructions for automatic and manual time setting.
The manual can be downloaded here (direct download link):
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3043.pdf
Jun 24, 2014 | Casio PATHFINDER ATOMIC SOLAR WATCH...
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How do i set the tide function on my casio sea pathfinder
    Check my tips. There you will find manuals for all Casio watches.
    Aug 26, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Setting my casio pathfinder 2632 to military time
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please.
    Mar 25, 2010 | Casio Watches
    Tide time
    Mar 21, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Resetting the time
    How do I set the time on my Baby G Sea Pathfinder?
    Jun 07, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Hello i recently purchased a casio pathfinder but have mislaid the instruction leaflet it seems to work differently from other watches which i can set easily is it possible to have a leaflet downloaded its...
    Hold down the adjust button (top right) and flick through with mode (bottom left) when you are done hit adjust again and it will take you to the next 'page' of settings. Same deal there. Use the top and bottom left buttons to change number up or down
    Good luck
    Dec 01, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Watches Logo
    26 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
