Question about Canon PowerShot A520 Digital Camera
Canon powershot A540 digital ...problem it shown card locked
Canon powershot A540 digital is my its working all program but the one problem is that when i click photo then shows card locked so plz tell me what is the solution on that
  • fppph Sep 19, 2008
    I alreay unlocked the memory card, still the problem persist. I tried testing the multimedia card on other devices, it worked fine, so no problem with memory card. I tried inserting on the camera other memory cards, it showed card locked.
    Thank you
  • thinwhitedog Mar 19, 2009
    my memory card is unlocked, but still have the same problem
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Look for the tiny slide switch on the side of the card. Slide this switch back to the unlocked position (opposite of whatever its at now).
Posted on Aug 02, 2008
Thanks a lot from you cause i did that and now its all rights ok.do this:Remove the SD card from the camera. Look for the tiny slide switch on the side of the card. Slide this switch back to the unlocked position (opposite of whatever its at now). for everbody who have problem with card locked....
Posted on Mar 26, 2009
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
My memory card is locked and i tried everything i have a canon a540 powershot and the memory card is a sandisk 8gb
Have you noticed the slider on the side of the card? This acts as a lock and might have been accidentally moved to the locked position, in which case you could just move it back to unlock again. Hope this helps.
Dec 27, 2010 | Canon PowerShot A540 Digital Camera
Canon powershot A540 I have tried to erase memory card but it says card locked. How do I unlock.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
Formating a new card for the Canon PowerShot A540
Here is how you do it.
1) press the menu button.
2) scroll right to the Setup Menu
3) scroll down to format.
4) scroll right to enter Format Menu
5) scroll up to Low Level Format.
6) scroll left or right to add a check mark.
7) scroll down to ok and press the function/set button.
Sorry no one got to you sooner. Hope this helps you, and thanks for coming to FixYa. Don't forget to rate my solution.
Rob
Jan 08, 2009 | Canon PowerShot A540 Digital Camera
There's a little switch on the side of the SD card. Remove it from the camera and find the switch. Normally, there's some very small printing next to it saying something like (Lock / Unlock).
Mar 27, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital...Problem
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Jan 01, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A520 Digital Camera Logo
371 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
