My hotpoint aquarius wf630 digital display shows TEST
    Brigadier General:
  • 6,277 Answers
I cannot take credit for these instructions- they are from the UK Whitegoods fault code guide.
Check the date code on the plate.
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
I hope one of these helps.
John C
Posted on Mar 13, 2011
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
My hotpoint aquarius is coming up with test and will not start when I have gone to use it it came up with the time and temperature but then it just said test and will not move on
hello try this Someone has accidentally pressed some buttons and locked you into test mode.
Your machine should now work. hope it helps
regards
shaun
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have somehow managed to put my hotpoint aquarius into test mode
Mar 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
My washe keeps reading either F04 or F05
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Error message LE5E and would only oparate prewash
it's not on 'test' is it,
try turning the machine on while pressing the start and on buttons together until dOFF apears.
Jan 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
