Question about Sony Playstation 3 (PS3) Console
Hi! I have problem with my PS3. I cant get HDMI pic or sound, and the only port that i can play with is AV2 (component with scart adapter). If i connect HDMI cable to HDMI 1 and PS3, nothing happens, expect strange sound is coming from tv when i switch to channel AV2. Same happens if i connect it to HDMI 2, exept that there is not that strange sound. I tried to play with only component, that did not work either.
    President:
  • 1,139 Answers
Hello there, please try my guide out to see if you can sort your display problem -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Posted on Mar 13, 2011
I have a 27 inch syphonic flat screen tv and I'm trying to get it on an input channel in order to play my Xbox 360
I dont have a 360 so cant be 100% sure this will be helpful. i have a PS3 and to get it to run on HD after using it on SCART, you need to plug both the HDMI and SCART leads in simultaneously and go into the system visual settings and change it to a HDMI port.
after this you need to jsut unplug the SCART.
im hoping its a similar issue but just swapping the PS3 menu's with the 360 one.
Oct 06, 2012 | Televison & Video
Tip
How to connect PS3 to surround sound
Firstly if you have a HDMI Supported TV, change the video output settigns to HDMI on the PS3
Then change audio output to scart.
Then remove the scart block from the Scart that came with the PS3 and connect the red and white into the co-insiding ports on the back of your surround sound DVD player.
Set DVD player to AUX and away you go!!!!!
Hope this helps
on Apr 10, 2010 | Televison & Video
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Problem
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
