Question about Refrigerators
Freezer down to -32 degrees - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Mar 19, 2011
New 5 cu ft chest freezer cycles on every 30 min. Grumbly sound. 1 notch from 'coldest it only reaches 5 degrees. Freezer 3/4 full.
look in your onwers manuel and it should tell you what your temperature for the freezer should range from.if it was not giving to you when you bought the freezer then it should be behind the pannel down where the compresser is taped to the side.but as you know any thing below 32 degrees is freezing so 5 degrees is pretty cold.i dont under stand about the noise but if you think your freezer is not working right and if it is new then call place where you got it and tell them your concerns and then they should send a technician out
Feb 18, 2013 | Freezers
Freezer temperature came up to about 35 degrees. We took all food out. Temperature is holding around 32 to 35 degrees. This is on the colder setting that used to read around 0 degrees. What do I need to...
If there is frost on the back of the freezer then there is a defrost problem. If no Frost then i would advise you to take the back off the freezer and see if there is any frost on the coils. If no then the compressor is insuffecient and or no freon.
Mar 14, 2011 | Freezers
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I am trying to return the freezer and refrugerator settings to 37 and 0 , how do I do that?
There is a dial or button pad inside the fridge that controls the temperature up or down.
some displays are not so clear so just adjust your fridge slowly either way until you get to the desired temperature
37 degree Fahrenheit = 2.78 degree Celsius
0 degree Celsius = 32 degree Fahrenheit
Oct 28, 2010 | LG Refrigerators
GE PDS22SBRR bottom freezer not cooling. I adjusted the controls to cool and overnight it goes to 0 but if I open the freezer just once the temp jumps to 12 or 14 degrees. Please advise, thanks!
This sounds like a pretty normal condition. How long after you open the freezer does it take to recover (i.e. go back down to 0 degrees)?
The freezing temperature of water is +32 degrees Farenheit, so as long as your food is staying frozen, I wouldn't worry so much about it.
Is this a new (different) condition or are you just now noticing it?
Good luck. Hope this helps.
Sep 12, 2009 | GE Profile PDS22SBRR Stainless Steel...
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Profile Artica Freezer is warming up to 32 degrees
There are 2 dials in a refrigerator. One is the thermostat the other is the air damper between the freezer and the refrigerator section. make sure your air damper is open about 1/2 way. If air does not get from the freezer to the refrigerator the thermostat might not be reading a proper temp. If you open the damper to much then you can start freezing food in the refrigerator. Some refrigerators have a opening back to the freezer down behind or beside the chrispers sometimes a paper or wraper can get down there and block air off from returning stoping the normal cycle.
I don't know if this is a solution but they are easy to check and eleminate as a possibility.
May 20, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
