Question about PNY GeForce 7600 GS, (512 MB) AGP Graphic Card
GE force 7600 gs
I have recently installed this card on recommendation from local store. All of the games I have subsequently loaded will not play correctly. The graphics start fine then go into large lines sometimes completely obscuring the screen. Ive tried everything ! help !
  • Cisf May 11, 2010
    - have u installed the latest drivers for it ?!
  • 476 Answers
Unistall this unit and reboot ,
if the problem still exists then back up the info you need and then consider formatting this unit
or
restoring it back to an earlier time before the card was introduced,
either solution will fix the problem,
Now that everythings working again search the model of the card you have and read about the card specs and or the reveiws about the cards ratings,compared with your computers specs,
More ram may be required for the card to perform properly,
once back to normal,
then try to reinstall the card again,hope you got the disk?
If it turns to custard again then consult the store you got the card from and ask them to demo the card for you.
or
you demo it to them.
WARANTEE ISSUES..........Consumers have rights.
Posted on Aug 01, 2008
GUys, I installed ZH today, and wen i tried to play it, it says this..Technical Difficulties....You have encountered a serious error. Serious errors can be caused by many things like viruses, overheated...
I had the same problem with zero hour
You'll need to download the original iso image then install the game again
and if you're running the game on W7 try to run the game under windows xp under proprieties
Enjoy!!
Jun 28, 2017 | Computers & Internet
Hello i tryed to hook up my GeForce 7600 GS / 512MB to my 32 inch flat screen i played with it to get it centered to my tv not i get nothing on my lcd but windows start up then nothing after windows start...
You need to set the tv's setting as well, and not all tvs will accept the input from video cards on all resolutions.
Try changing the screen resolution and see what your TV will accept....or goto the tv's website and find the specs that list what resolutions it can except.
Jan 12, 2010 | SPARKLE Computer Sparkle GeForce 7600 GS /...
Geforce 7600 gs Graphics card - No Output
ooks to me you have a OS error, if you are using XP or Vista try doing a repair, then try reinstalling the VGA card Driver.
Mar 21, 2009 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
MSI K8N --Compatible video card
Get another GForce video card a later model with at least 256Mb of memory. If you play games you might want a higher spec GForce video card.
Mar 15, 2009 | MSI K8N Neo4-F Motherboard
Added a ge force 8400 gs pci grfx card to hp a6120n monitor
Alright, let's give this a shot. Your system can handle it as the card only needs 71W of power.
Right-click your desktop and go to properties.
Screenshot.
Afterward select the tab at the top reading, "Settings."
Screenshot.
Now select your new video card in the, "Display" region and choose the device to be your, "Primary Monitor."
Screenshot.
Afterward try plugging the monitor into your new graphics card. It should work just fine.
Feb 03, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Garbled display with Geforce 7600GS
From experince I would still say this is a heat issue, I just went though this with my HD4870 ATI card. I was using an after market cooler wich was insuficent for cooling. All the symptoms point to a heat issue. Also since the card is 2 years old, its a good chance the VRM's have fried and any heat causes the card to basicaly shutdown in a manner of speaking. you could try getting the Accelero S1 cooler that would replace the fan on the card, then attach 2X120mm fans. Only problem is you can buy a newer better card. for example the 8600 GT is about 80-90$
http://ncix.com/products/index.php?sku=35559&vpn=EN8600GT%20SILENT%2FHTDP%2F512M&manufacture=ASUS
Jan 27, 2009 | Gigabyte GV-NX76G512P-RH NVIDIA GeForce...
Ge force 7200 GS /512 MB
You can always download the latest drivers from Nvidia at www.nvidia.com. Click the "download drivers" tab at the top of the page and fill in the information about your card. This way you'll have the newest software.
Jan 15, 2009 | Nvidia GeForce 7200 Graphic Card
Runescape on line game
Go Here and download the most recent update for Java. This does not sound like a videocard issue.
http://java.com/en/
Jul 02, 2008 | Acer Computers & Internet
Nvidia GE Force FX-5200 Troubleshoot
Not really a solution but just thought i would point out that the 5200 card is pretty old by todays standards and will only be good for playing games from a while ago. What games are you hoping to play?
Feb 13, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
In game graphic card goes mad.
I've only seen this happen when the card is failing- usually from heat (did you overclock the card?), sometimes from power reulation issues. Most likely, the card is ruined. What is the wattage on your power supply? Id the power supply is a little weak, spring for a better one- they aren't very expensive. Your best option is to return the card immediately, be careful if you overclock it, make sure you have enough fans/cooling apparatus in your PC case (these are also cheap), and make sure you have a decent PSU.
Jan 23, 2007 | ASUS EN7600GS Silent/HTD GeForce 7600 GS...
PNY GeForce  7600 GS, (512 MB) AGP Graphic Card Logo
85 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
