Question about Chauvet 2) Chauvet Double Derby X Dmx Led Dj Effect Lights
When i turn on the brand new double derby it works for 2 seconds and then goes off, what could this be and how do i fix it please Lily
  • Chauvet Master
  • 5,603 Answers
It is probably in the wrong mode. Since the light can be set for automatic, sound, and DMX we have NO idea what mode you are trying to run. Refer to page 8 and 9 in your manual for correct dipswitch setting for whatever mode you are running.
For eye protection, the lights must keep moving or they will shut down... which is likely what is happening in your case. If you put in auto mode or sound mode they should keep on. If in DMX mode and the mode does not command movement all the time, they will extinguish.
Posted on Mar 14, 2011
I need help my new dm10 mod comes up with calibration fail when I turn it on even with nothing plugged into it. I have updated the firmware it just wont talk to the kit at all
you have to make sure the red crash 1 is on the cymbal w the choke zone on it and plugged into crash one on the module. crash 2 goes in the cymbal w no choke and plugs into perc 2 on the module. also make sure the ride zones are plugged in to the corresponding zone on the module. bottom line double check all connections and reference the setup guide if u still have it. i had the same issue.
Jul 22, 2011 | Alesis DM10 (Module) High Definition Drum...
I plug my guitar to the amplifier and i get no sound at all..... only if i press the tunning button turns on & stays on for couple of minutes and then it goes off again....what can i do? P.S.: The...
The tuner on this is weird. It requires three presses of the tune button. Read your manual... One press turns on tuner and passes audio till it times out. A second turns on tuner and kills audio... the third press restores audio... Others have had the same problem understanding this three mode thing and the timeout in the first two modes is confusing when sound disappears.
May 14, 2011 | Takamine EG340CLH Acoustic-Electric Guitar
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
I have mine on the dmx setting for it to turn constantly and it's stopping and starting irratically flashing on and off so I'm getting hardly any effect from it at all I'm thinking it's a problem with the...
I am not sure if you are using a DMX controller or a standalone setting. If on standalone, sound triggers a random reversing, stopping and flashing mode. I am NOT sure that a stationary mode is available without being commanded by a DMX controller. If you are using a DMX controller get back to me and we will analyze what the problem is. If using a DMX controller, tell what address you are using and the length of the control cable.
May 01, 2011 | Chauvet 2) Chauvet Double Derby X Dmx Led...
Hi my name is Mike and I have a problem with my mini spot. It was working fine for about 2 weeks. Now right when i start, instead of it going through its intitial 10 second or so boot up (with the red led...
hey Mike, I just got 2 brand new minspot rgbws and they worked for 3 days and now tonight the same thing!
they power up and goto a white light and dont move. no display on led panel either...
did you find a fix?
Apr 11, 2011 | Chauvet Minspot Rgbw Min Spot Led Mini...
What kind of fuse do i need for it
The unit uses two 300 watt halogen lamps so it draws around 5 amps for just the lights and a small amount for the motor. The E108 is a carbon copy of the Chauvet Double Derby that used the halogen bulbs. My Chauvet is marked as using a 7 amp fuse for 120 volt operation or a 5 amp when used on 230 volts.
PLEASE open the unit if the fuse blew as it is likely there is an internal problem if nothing more than a light bulb that shorted as it burned out. There are slip rings and the sockets that need to be inspected if the fuse did blow.
Feb 25, 2011 | Eliminator E108 Double Derby Dj Light
The problem with my marshall ma100h amp is that out of the box brand new it stopped working within a few days. Earlier I turned on the amp power switch and let it warm up. About a minute later I kicked on...
Brand new? Take it for warranty repair IMMEDIATELY... don't mess with it !!!
The only thing for you to check is that you did not turn on "STANDBY" as this shuts down the power amp and the capacitors will bleed off and sound will fade. Try switch in both states before complaining
ONLY use the amp in STANDBY for a brief period (20 seconds) to let the tubes warm up... Leaving in STANDBY for a long period straains the input filter capacitor. If you are done with using the amp, turn it off...
Jan 14, 2011 | Marshall Amplification Marshall MA100H and...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Chauvet 2) Chauvet Double Derby X Dmx Led Dj Effect Lights Logo
98 people viewed this question
Top Chauvet Music Experts
Michial Gueffroy
rhodesworks
James Kovacs
James Kovacs
Are you a Chauvet Music Expert? Answer questions, earn points and help others
