Question about Sewing Machines
How do I thread a singer 498 both bobbin and top
Error 1
Posted on Mar 13, 2011
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
