Question about Seagate FreeAgent GoFlex TV Hard Drive
Getting IO ERROR STOP PLAYBACK on goflex tv with harddrive in docking bay. if i connect to usb cable it works fine. harddrive seems to be warm when i remove it from docking bay. i have had 2 goflex tv and 750 gb drives with the same problem seagate says they never heard of problem. i like the product but if it is going to lock up all the time its not much good. thanks Krat
  • 13433 Answers
SOURCE: Seagate Barracuda 200 GB 7200 RPM
can you take a snapshot from the smart page?
Posted on Feb 22, 2008
  • 139 Answers
SOURCE: Forgot Encryption Password
Visit seagate website else format in dos prompt
Posted on Feb 10, 2009
  • 18 Answers
SOURCE: Seagate Freeagent 500 GB does not detect
please format theExt HDD as soon as possible
Posted on Mar 21, 2009
  • 630 Answers
SOURCE: Seagate external drive locked in "read only" ,was working fine...
This seems to happen when it's been connected to another computer. Are you running FreeAgent Sync? If so force a sync and the read only problem should go away.
Posted on Aug 28, 2009
  • 979 Answers
SOURCE: Seagate Free Agent DeskTop 750 gb stopped working
Good day maam, hi, sorry to say this but, you lost your hard drive already. You lost your Files to. There are slim chances you need to pay for HArd drive recovery, this are offered by some private company check out this website: http://www.harddriverecovery.org/
Posted on Dec 17, 2009
Windows has stopped this device because it has reported problems. Code 43 This message pops up in when i plug in my SeaGate Free Agent GoFlex hard disk.
Try this as a possible fix.
This trick can quickly fix many mysterious hardware failures
The other thing I've heard of happening is a few of the USB 3.0 ports having problems with USB 2.0 equipment. I know it should be back compatible, but Windows can have problems. Try another USB port to see if that helps.
Does the SeaGate cable have 1 or 2 connections to the computer? Unfortunately, most external hard drives need to connect to 2 USB ports to get enough power.
I just looked up this problem on Seagate's website, and they pretty much come up with the same answers. Uninstall and re-install the USB drivers with the SeaGate connected. Or use other USB ports. The other suggestions they have don't make sense, if you can't talk to the thing, how do you run Seatools or checkdisk?
Fixya doesn't allow me to put in another link at this point, so you'll have to copy and drop this into your address bar.
http://knowledge.seagate.com/ka030000000tmkPAAQ
Here's another write-up on fixing the code 43, I wouldn't do number 6.Update BIOS though, USB is working fine with everything else, it's NOT the BIOS that's having a problem.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
Jul 26, 2016 | Seagate 500GB FreeAgent GoFlex Hard Drive
When I plug it into my computer, it says 'access denied' and prevents me from transferring my pictures to the goflex harddrive.
Sounds like Microsofts nuts user file access system. Try connecting to a non-windows machine i.e Linux - if you see the files, that's your problem.
Jun 14, 2015 | Seagate FreeAgent GoFlex 320 GB USB 20...
Seagate Freeagent goflex not detecting
It sounds like the drive is failing. So you will need data recovery services.
A remote service is http://FreeDataRecovery.us
Aug 29, 2012 | Seagate FreeAgent GoFLex 500GB...
My Seagate harddrive experienced a code 10 error, how do i fix it
code 10 error no driver
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 07, 2012 | Seagate FreeAgent 2TB GoFlex Desktop USB...
My Seagate Freeagent Goflex 1Tb external USB hard disk is not detected when connected. but the light on the diskdrive comes on. Pls advise.
Hello Gravi,
Please try one of the following options.
Try different USB ports.
If that didnt work, then try updating/reinstalling your USBdrivers.
Try after these options a reboot first.
Also take a look at this page where some driver problem for your specific harddrive are explained!
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
I hope this helps you out!
With kind regards,
MisterN
Aug 12, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
How do I get the saved files from my GoFlex on my new computer
You should be able to just plug it in to USB and read them since the harddrive has aleady been set up and used. The new machine should read it just like it will read a thumb drive you've saved files on. This is one of the big reasons why people like these external drives :) You can take them with you and use on another computer.
May 28, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Viewsonic VX 1945-wm-3 not detecting iPod Mini 4GB 2nd gen
USB device not recognised" - means windows needs driver to function. As soon as you connect USB device it check driver in cache it is available it detect smoothly you can perform else it generate errors.
first to instal driver from CD
May 24, 2008 | Gateway FPD2275W LCD Monitor
JVC Everio GZ-MG37u Cant Connect to Pc
how to export video from camcorder to windows movie maker because power producer sucks!!!!!!!!!!
Feb 24, 2008 | JVC Everio GZ-MG37 Camcorder
Seagate FreeAgent GoFlex TV Hard Drive Logo
408 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
