Question about Sony Audio Players & Recorders
Sony mhd gx 2000 audio cassette player doesnt work and when i switch to cd mechanism error displays
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
Tape motor is done an the cd is probly hook up 2 it
Posted on Mar 16, 2011
The system just shuts off after the word "eject" appears on the screen.
It is likely mechanical disassembly will be required to extract the damaged cassette in the B drive and the jammed cassette in the A drive. The electromechanical A-B switching mechanism may have failed because of age aor failure of synchronization. The tapes, if very thin or stretched could be a contributing factor.
Feb 26, 2014 | Sony DHC-MDX10 Shelf System
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
When I play cassettes the tape comes out the bottom of the cassette and gets wrinkled
one of the drive wheels has siezed i expect if you can trick the close switch and press play do both wheels turn ?? if one doesnt give it a turn to free it up
Dec 26, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
CD's keep spitting back out of player which is in caravan
The drive(optical) drives door mechanism has malfunctioned. If the PC CD drive can be replaced that would be the best, but repairing is also not cost-effective...........sodeep
May 12, 2009 | Sony CDX-L400X CD Player
Audio display says check cd
This may be a bit late to help, but I just had the same problem yesterday. Same car (2000 Monte Carlo SS), but mine is just the CD/radio stereo (no cassette). I was able to solve it by pulling the fuse for the radio (it's in the right-side panel) and letting it sit for a minute. After putting it back in, the CD player made the disc ejecting sound one time (no "check CD" message) and stayed off. And now it seems to be working fine. We'll see how long it lasts, though.
Mar 25, 2009 | 2000 Chevrolet Monte Carlo
URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
May 18, 2008 | Audio Players & Recorders
Connect audio components for recording Cassette to CD
Try this since you do not supply model numbers. If your receiver and CD have digital audio connector (coaxil or fiber) hook the receiver output to the cd input.
If you do not, see if there is a spare set of RCA jacks for output. If not, just hook up the cd player in the cassette jacks-there is always a cassette in and out-and hook your cd player to an auxillary input or use the cd player input.
Remeber though, cassettes have inherently more noise than cd so your cds will not sound like a pre-packed cd.
Dec 22, 2007 | Sony SS-X90ED Main / Stereo Speaker
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
