Question about Garden
A job to start,but when it dose it only runs for a few seconds and then cuts out.It is a Honda Rotary.
    Novelist:
  • 111 Answers
I would check your air filter and spark plug for the Honda engine. Also you may have water in your fuel tank and carburetor. If there is grass built up on the air filter, replace it. If the spark plug has a black charcoal like substance on it then you will need to clean it. A wire brush will work ok for this. If you do these things and it still won't start then I would empty the fuel tank and drain the contents of the fuel bowl on the carburetor. This is done by loosening a 10 mm bolt on the side of the fuel bowl. Let it drain for a little while and then put some fresh fuel in the fuel tank, after tightening the nut on the side of the carburetor. At this point if the unit will not run correctly I would take it into a Honda Power Equipment repair shop and let them take over. I like to tell my customers, "If it won't start with one or two pulls something is wrong."
Posted on Apr 03, 2011
What causes engine to cut out?
Maybe your coil pack. It can overheat and short out. Then it cools down and will work for a while till hot again.Could also be spark plugs and wires.
Feb 12, 2016 | 1999 Honda CR-V
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
May 31, 2015 | Cars & Trucks
2011 polaris ranger cutting out
clean carb and all fuel delivery system lines
Mar 25, 2013 | Polaris 2011 Ranger 800 XP EPS
Have a Honda EM5000S generator issue. Will start easily, run for a few seconds, then cut off. Problem just started. Checked spark plug, air filter, fuel line. All fine. Any ideas would be appreciated.
I sounds like it might be the low oil shut off. it has a bypass that allows it to start but then cuts off after a few seconds. even if the oil is fine the sensor may be bad.
Aug 10, 2011 | Mi T M MiTM 6000 Watt 13hp Honda generator
WHEN IT IS PUT UNDER A LOAD IT WILL NOT STAY RUNNING UNLESS YOU LEAVE THE CHOKE ON
Possible that the engine is not getting sufficient fuel for running and so the choke action is needed. You need to check if the oil switch is cutting off the power, - if so replace oil.
Secondly the fuel settings might need a check up. You might need to clean/reset the plugs/spark gaps and also overhaul the carburator to solve this issue.
Jul 08, 2011 | Honda Electrical Supplies
The engine cut out then right away was running again then 20-30 seconds later completly cut out again. After a few minutes it started again and ran for another two days. Then it cut out again, ran for...
- When was the last time this car had a tune-up? Could be as simple as that. New spark plugs/rotor/distributor cap/condenser might do the trick.
Other causes could be:
- bad fuel pump relay (definitely first on the list of things to check, and cheapest to fix)
- clogged/old fuel filter
- bad fuel pump
Mar 01, 2011 | 1991 Honda Civic
Tiller starts and runs for a few seconds only with choke on
Sounds like you have a dirty carburetor. Might be able to get it going with a dose of carburetor cleaning in the gas tank (Sea Foam is good), about a 1/4 cup is more than enough. You need to start and run it a couple times to work the cleaner in to the carb. Then, let it sit a day or so.
Other than this, remove carb and do a good cleaning with spray carb cleaner in all the jets. If there is a brass bolt on the bottom of the carb that holds the bowl on, it may very well have 1 or 3 itsy bitsy teeny tiny hole, almost invisible to the naked eye. They HAVE to be open. Did I mention that they are small???
Aug 09, 2010 | Cub Cadet 1 Rotary Tiller Operator ...
I start the engine it will run for a few seconds then dies
its suffering from fule shortage most likley a blocked running jet in the card ,,,strip the card and clean out the jets with comprested air or card cleaner,,, dont go poking wire into the jets to clean them or you could distroy them,,that why it only runs on full choke
Apr 03, 2010 | 2002 Honda CM 125 C
I have a cold start starting problem with my 95 honda civic hatch
leave it to the specialists aye haha but if it was me id go for a dig i was just tryn to find a manual for my van to simplify the process
Jan 05, 2009 | 1995 Honda Civic
89 HONDA CIVIC WILL NOT STAY RUNNING
Sounds like the fuel pump may be going out. I'd have it checked.
Dec 15, 2008 | 1988 Honda Prelude
Garden Logo
292 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
