Question about Western Digital My Passport Essential 500GB External USB 20 Portable Red 500 GB Hard Drive
My wd essential external hard disk is becoming very slow to copy and past a file and some times cyclic redundancy occurs
  • 93 Answers
Try using a different USB port and change your cable.
Posted on Mar 13, 2011
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Cyclic redundancy error when copying backed up files into Itunes
Files with cyclic redundancy errors means these files are corrupted and cannot be copied. Since you cannot copy these files from your faulty hard disk again then these songs are lost and you need to download them again.
Nov 27, 2012 | Apple iTunes
Hard disk cyclic redundancy check
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
My older WD hard drive suddenly became inaccessible. I sometimes get a cyclic redundancy message and sometimes it says windows cannot access the drive. I assume I need to try data recovery? Suggestions?
This usually occurs when the drive becomes damaged or the files corrupt. You can try using thirds party disk repair software or take it in to a professional to recover.
Feb 28, 2011 | Computers & Internet
I am getting the data error (cyclic redundancy check)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Jan 31, 2011 | Western Digital My Passport Essential...
    HI GOOD EVENING I AM UNABLE TO COPY MY MICROSOFT OUTLOOK 2007 PST FILE TO EXTERNAL HARD DISK. AFTER STARTING COPY FEW MINUTES LATER I FACE THE FOLLOWING PROBLUM CANNOT COPY OUTLOOK:DATA ERROR(CYCLIC...
    A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
    When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
    and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
    Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
    Try to copy the PST file to another file on your 'C:' drive.
    If you do not see the "check", then it is the external disk-drive that has a problem.
    If you do see the "check", then open Outlook, create a new folder,
    and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
    Sep 07, 2010 | Computers & Internet
    Unable to copy files from cd
    Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
    Thanks
    Mar 01, 2009 | Computers & Internet
    Open Questions:
    Western Digital My Passport Essential 500GB External USB 20 Portable  Red 500 GB Hard Drive Logo
    525 people viewed this question
    Top Western Digital Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
