Wont spin or turn the drum belt is intact - Washing Machines
  • Washing Mach... Master
  • 1,525 Answers
Hello sound like it could be the brushes on the motor 2 plastic block sit either side of the motor they are made of carbon these wear down can cause the motor stop working they just slide out
regards
shaun
Posted on Mar 13, 2011
Drum does not spin. Belt appears to be ok
You have a bad tensioner or a bad motor. The tensioner for the belt can drag the motor. However, what you are describing sounds like the motor is shot. But make sure you are getting correct voltage to dryer and nothing is binding the motor.
Mar 03, 2015 | Maytag Dryers
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
The dryer was making shrill noises for some time, then a thump noise, now the drum wont turn. I think it is the belt, but the belt is still intact... Where on the drum does the belt go? and what else might...
The belt may have jumped off the tension pulley. Check to make sure the belt is tight around the drum and all pulleys, then check whether all pulleys and rollers turn freely.
Jun 30, 2011 | Dryers
Motor/Drum doesn't turn/spin & belt appears to be OK
With the belt off can you spin the motor freely by hand? If no then the bearings are froze and the motor has to be replaced. If yes and the motor will not start when power is applied then the motor needs to be replaced. If it starts without the belt on but not with, then the drum is bound somewhere and has to be freed.
Eric
Jun 11, 2010 | Kenmore Dryers
The drum does not turn.
there are two potential problems. firstis te belt to the drum drive pully from th moter. this is the easiest. take off the back panel an seeif the belt is intact. if so run through a cycle and see if the motor spins or triesto spin. if not this is most likely thesuspect. one plug three screws and about100 dollarsfixes te motor. hope this helps.
Dec 18, 2009 | Kenmore 44102 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
