I installed/ changed all the 4 color (brand new original) in my printer (HP laserjet color 3600n), but till now (nearly 15 days) it is calibrating. I did cold reset, skip calibraing and others. But nothing happned. so, please help me to solve this issue
    Novelist:
  • 66 Answers
Having dealt with this issue only once before on a similar model I would say that the problem is one of the toner cartridges. After it calibrates for a few minutes open the front door and look at the Electrostatic Transfer (ETB) Assembly. There should be smudges/evidence of all colors on the belt and if any are any missing then that toner cartridge for that color is probably the issue.
I'd inspect the toner in question to ensure that it's seated properly, all the stickers/shipping protection is removed, and that it isn't so old that the toner might be one big clump and unable to be pulled by the pritner.
Hope this helps!
Posted on Mar 13, 2011
I installed new cartridges (4 colors (B, Y, M & C) and closed the top cover, it calibrating continuously for a week and more. So, please help me to solve this issue. My printer model is HP Laser Jet...
Hi I'm sorry to say its normally a faulty cartridge.
You now the black belt in the front of the machine well the machine when it calibrates prints a pattern on the belt and it uses this pattern to calibrate its self but if the pattern is not on the belt it can not finish the calibration.
solution replace the toners one at a time until you get it going
yours Ian
Mar 08, 2011 | HP LaserJet 3600n Printer
Cannot stop my HP Color Laser jet 3600n printer from calibrating
Use service mode to skip calibration on startup. Then perform quick calibration when ready.
Dec 23, 2010 | HP LaserJet 3600 Printer
My hp 3600n is stuck in calibration. how do i fix this?
I created a page on my blog where I outlined how I fixed this problem with my printer. I detailed the process and included some pictures http://www.mikekrauss.com/115/hp-3600n-constantly-calibrating-fix/
May 11, 2010 | HP LaserJet 3600n Printer
I also have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? I seen another posting with the same problem. I can not find a solution.
In the menu reset the memory and all active i/o channels. If still problem encounters then try replacing the cartridge. I think cartridge has some problem
Jun 23, 2009 | HP LaserJet 3600n Printer
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
May 26, 2009 | HP LaserJet 3600n Printer
Hp Color LJ 3600 continue. Calibrating
Had a similar problem with a customer's printer. HP tech support had me change out the environmental sensor and the boards, this did not fix problem. In the end we had to get a replacement printer (thankfully the unit was under warranty)
Jan 10, 2009 | HP LaserJet 3600n Printer
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
251 people viewed this question
k24674
jasbo
jasbo
