Question about Panasonic TH-37PX50U 37 in. HD-Ready Plasma Television
Hi there I have recently bought a Panasonic Viera 32", I have installed the Sky Box and Bush VCR/DVD Recorder Combi correctly but when I turn onto AV2 and switch on the DVD player the screen comes on but is bright green! I have tried all suitable tuning methods and have been through the installtions time and again and checked all cabling but it will not change, it can't be the Bush Combi as it worked perfectly with my previous Samsung set, this is really frustrating, I can't see that it is a fault with the set as the Sky works perfectly and I have tried the connections on both AV1 and AV2 and it makes no difference
5 Suggested Answers
SOURCE: How to make AV1 input the default when switching
Thanks. Problem solved. I found the operating instructions and read them!!
M.J. Ramage
Posted on Sep 10, 2009
SOURCE: Hi there I have recently bought a Panasonic Viera
Have you tried a new scart lead
Posted on Jan 04, 2010
  • 18 Answers
SOURCE: i have a 42 inch panasonic viera th-p42g10a. i
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Posted on Mar 03, 2011
bobhifi
  • 635 Answers
SOURCE: I cannot record from a Daewoo DVD recorder (
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Posted on Mar 08, 2011
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Panasonic Viera
vga board is bad ot the components on it are blown out.
May 08, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Panasonic TH-37PX50U 37 in. HD-Ready Plasma Television Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
