Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
We are converting from a PC to an iMac. We backed up all files to the flash drive which is a NTFS format. I soon discovered the MAC is not compatible with it and I cannot transfer my files. It seems that I need to erase and re-format the flash drive FAT according to blogs. Please confirm this is the process and if so do we then connect the re-formatted drive to the PC and perform the back-up again and will the PC be able to transfer files to the external drive under a FAT format?
  • 32,281 Answers
The MAC can read PC formatted USB flash drives BUT the USB flash drive MUST be formatted in FAT32 not NTFS.
I have a MAC and I also transfer photos from my PC to my daughter's MAC notebook.
You can also transfer files from the MAC to the PC using these FAT32 formatted USB flash drives.
Posted on Mar 13, 2011
Testimonial: "Thanks for help - tested a file transfer and everything seems fine"
I have an external WD My Passport hard drive but Pages says it cannot create a file when I try to save a document on the external hard drive. Is it because the file format is not compatible with Imac? Can...
Apple Pages has a few bugs like this. There is a work around.
  1. Save to Desktop or Documents folder on the System Drive
  2. In Finder, move the file to your external drive.
  3. Now when you open the file from your external any saves will continue to go to your external drive.
It's a bit of a pain but works for now.
All the best
Mar 29, 2015 | Apple iMac Desktop
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
I can't restore pc formatted external hard drive back to Mac use
You probably formatted your harddrive in NTFS. NTFS is a so called "file system", but it is designed by microsoft, it only works on microsoft systems and on some linux distributions. However it is not compatible with mac.
So what now? You can go and find software that makes your mac ntfs compatible, or you could backup the files on a windows computer, format your drive in FAT32 and copy the files back to the drive. Take a look at this: http://macntfs-3g.blogspot.com/ That should make your mac NTFS compatible.
good luck!
May 29, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Sandisk 16GB Cruzer with U3 download to iMac ???
If the file is an .exe, then I recommend getting a wine based launcher such as Darwine. Try running it in Darwine, Wine or a similar program, if that doesn't work, then try formatting it to FAT32 (usable by both Windows and Mac [But you can't transfer files over 4 Gigabytes in size if you need that] ) or NTFS (and downloading MacFuse and the NTFS / 3G plug-in to be able to read and write NTFs on Mac) and not using the programs that came with the Flash Drive.
May 02, 2010 | Computers & Internet
Hi,i just got an imac,plugged my philips hard drive in to it and it plays files off of it no problem,only when i want to download anything onto the hdd from the imac it won't go there,does anyone know the...
Hi Jay,
Sounds like the phillips drive is formatted in NTFS (windows file system). Mac OS knows how to read files on windows drives but cannot save to this file system.
If you need to move the drive between Windows and Mac PCs you will need to either format it as FAT32 if it's small enough which is compatible for both or you will need to format it with the Mac then install MacDisk on the PC so it can read and write to the Mac file system.
Either way, copy your files off the drive to your PC before reformatting it.
Feel free to comment back if you need more help or read my FAQ on the topic. The top half of the article will cover your needs.
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Chris
Mar 26, 2010 | Computers & Internet
PC/Mac compatability issues
Hi
Is it formatted in NTFS? OSX will read most formats but cannot write to NTFS.
I would suggest that you copy all your files from the drive on to the Mac then use disk utility to reformat the drive in the native Mac format and then copy everything back again.
You may find that once formatted, Time machine will pop up and ask if you want to use the drive as your time-machine back-up. If the drive is the same size as the Mac's drive (or smaller) I would say NO and get a larger drive to use for TM.
If you need to connect the drive to a windows machine at all then don't use the native format (HFS+), use FAT instead. The mac can work with that (although it will probably mess up your files names).
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
Got a new imac moved ms office file to my book -
Try to change the File system of the hard drive to FAT. It is currently in NTFS. Mac recognizes NTFS file system as read only. You must use the disc utility and format it with a volume format of MS DOS.
By changing it to MS DOS (FAT) you can use it with Mac and PC. Readable and writable.
Aug 04, 2009 | Western Digital My Book Essential Edition...
Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Mar 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
206 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
