Question about Panasonic KX-FPG378 Fax
Error Code 877 UF S1 - Panasonic KX-FPG378 Fax
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Need replacement hand set for UF-S1
The "static" may be the curly cord rather than the handset?
I know Fax line leads are non-standard but you could try a curly cord from another phone or fax?
If you are in the UK there is one UF-S1 machine for sale on Ebay at 0.99p with 9.00 postage. Says it working with instructions and roll of paper. here is link to it
May 21, 2009 | Panasonic Office Equipment & Supplies
Error Code 720 on Panafax UF-9000
error 720 means unable to connect to the POP server.. incorrect POP server ID or POP server is down
Apr 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic UF-490 erroe codes 887 & 054, how to clear?
Your laser unit has failed. It's uneconomical to have it repaired.
Mar 05, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Panafax uf-S1
See if there is a "slider" on either side of the machine.
Oct 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax UF-S1
greška 406 način osoba te┬×ak to faks te nema pravo lozinka
ukoliko ištanje prevoditi u engleski jezik ugoditi iskoristiti povezati rika
http://intertran.tranexp.com/Translate/result.shtml
Sep 18, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Where can I get the latest update or downloads for GPS Pioneer avic-s1
Yes I called the Canad number 1-877-283-5901 and they asked for 150 $ for this upgrade. Now a day, one can buy a cheaper new GPS in that amount. I am not going for this option.
Dec 26, 2007 | Pioneer AVIC-S1 GPS Receiver
Panasonic KX-FPG378 Fax Logo
37 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
