Question about HP DeskJet F380 All-In-One Printer
I think i must not have the printer set up correctly im on window 7 and when i put the disc in to install the printer it said it was not compatible so i downloaded it from the internet when i go to print a page from my PC i select the printed but it prints notting it was scaning to my pc though i did check that i had taken the protective tape off the ink, i think i must not have it set up properly?????
  • HP Master
  • 1,381 Answers
Hello annmarietp
Delete the installed software in Control Panel \ programs .
Disconnect device .
Reboot .
Install driver. Connect device and wait for confirmation of successfull operation .
The correct driver can be downloaded from here :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1128296&
Please make sure you have selected the correct OS at HP's before downloading .
Regards , fanaudi ;
Posted on Mar 13, 2011
How can I make my JVC Everio GZ-MG21 compatible with windows 7
I have used my Enviro MG21 with windows 7 and now Win 8 with no problems so I don't think it is comparability issue.
Try opening up "My Computer" and see if Enverio appears as a device, if not try adding it via "Control Panel - then add device abd manually install via the on screen instructions"
Jul 15, 2014 | JVC Everio GZ-MG21 Camcorder
Have windows 7 on new computer, installed Adobe Pagemaker which is fine but want to turn files into PDF format, message say's no printer driver installed. Have tried to install but windows will not let...
the printer will need to be installed in compatibility mode....un-install the printer from control panel.
pain in the **** i know, but least you'll know from now on, how to install older programs & drivers in to windows 7....
if your installing from a disk, then put the disk in, then when the auto run box comes up, close it...
open computer instead from the start menu.
right click on the cd drive with the disk in, & select open.
drag & drop the contents of the disk on to your desktop....make a new folder to put it all in, if you need to.
then once it's copied across, right click on the install/application icon.
from the top of the menu click "check compatibility" if you dont see it,click off it & then try right clicking on it again untill you see it.
windows will scan & set itself to the right settings for that program.
then click try recommended settings.....followed by START PROGRAM.
if it all installs ok click next then click YES KEEP THESE SETTING FOR THIS PROGRAM NEXT TIME.
then go to the printers web site & update it with the latest software,thats if windows doesn't do it for you.....TIP:(white flag @ bottom right of screen)
do this with all older software.....windows 7 is **** hot when it comes to running older programs, im using a windows 98 program call photo express on mine...no problem.
GOOD LOOK MATE.
Sep 10, 2011 | Computers & Internet
I have Windows 7 on my laptop and my cd that came with my computer does not support Windows 7 for my printer.
It might be that the printer is not compatible with Windows 7. However Windows 7 has a compatibility Mode Feature
To Do This follow the steps at the bottom
1. Insert the Printer Disc
2. Click Start > Click Computer > Right Click on the Printer CD > Click Open/Explore
3. Right Click on Autorun.exe or Setup.exe and Click on Properties
4. On the Properties Window > Click on Compatibility Tab >Put a tick on the box that says Run this program in compatibility mode for:> Select the Operating System that printer is mostly compatible for>
Click on Apply> Click OK....Double Click on Setup or Autorun it should work or you may download the drivers or patch from the HP website
Thanks for Choosing Fixya
Jun 05, 2011 | HP Office Equipment & Supplies
Ever since I installed windows 7 I get an error message saying "cannot communicate with printer". I have re-installed from the disc and it prints out an alignment page but nothing is queued from...
First restart the printer and try to ping the printer IP from the PC
Command -- Ping -t ip of the printer,
if the ping doesnt comes there is problem with the cable
Feb 05, 2011 | Lexmark X2670 All-In-One Printer
I had same problem, even if I download de cjb3500_4500en the processo goes on but when I put to configure wifi (orange) they ask me to put a usb cable, but on actives the button do continue if the USB was...
You did a nice job trying out other ways to install the printer successfully. However, it's weird that 3 computers are not recognizing the USB connection. Make sure that the USB cable is plugged in correctly (in the right position) in the USB port of the printer.
Next, use the correct driver that is compatible with your computer's operating system. You may need to uninstall the existing software before reinstalling the new one. Instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T. Then, you can download the drivers at:
If problem continues, contact Lexmark technical support.
Oct 10, 2010 | Lexmark X4550 InkJet Printer
How do you set up a printer to windows-7 please
install the driver off disc that came with the printer. THEN
plug the pinter to the USB port and turn it on. A wizard will guide through the installation.
Sep 22, 2010 | Computers & Internet
Cossacks European Wars on Windows 7
yo change folder name Video -> video1. You will succeed. :D
Jan 23, 2010 | Strategy First Cossacks: European Wars for...
Just installed windows7 and hp5610 will not install
Below is the link to the drivers for Windows 7. These new drivers must be used for HP products or they will not install or work.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=441125&
Dec 06, 2009 | Office Equipment & Supplies
Unable to check cartridge ink level on new computer.
i think the problem is on that software.pls check the software cd or DVd. if it is fully compatible with windows vista.
Jun 13, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP DeskJet F380 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
