The HP DeskJet 824C will not work properly, even when I try to print simple sentences or diagrams.The printer is about 15 years old, do I need a new one?
  • 417 Answers
yes 15 years is about it(wow) for belt driven inkjets, HPs are pretty good ones stick with them, you will be amazed how far theyve come and the ink prices have dropped below regular fuel prices. You may have to download a specific vista driver even though your printer is brand new though, if you have vista. be prepared..
J
Posted on Aug 01, 2008
HP Deskjet 3050 missing lines when printing
Since the print head(s) are installed into the cartridges themselves, it makes this easier to troubleshoot. First, are all colors affected or just black? You don't say whether or not the cleaning pages and alignment pages are printing properly so I assume they have the same problem. Next, are you using genuine HP cartridges or are these remanufactured/aftermarket units? Non-genuine cartridges are often remanufactured many times over and eventually fail in use. If they are genuine cartridges, and if the problem appears to be only with either the black or the color cartridge, but not both, try another cartridge. New cartridges can be defective. IF that is the case, contacting HP about it should get you credit for a new one. If the problem is related to both cartridges and new ones don't fix the issue, then the problem is in the printer itself and there isn't much you can do about it other than replacement since printers are so inexpensive that repairs are not cost effective.
Sep 30, 2015 | HP Deskjet 3050-J610a
What is wrong with my HP Deskjet D2330, and why is it printing only blank pages?
well it has got to be the ink cartridge. wipe of the bottom of it and make sure black ink shows up
Dec 10, 2014 | HP Deskjet D2360 InkJet Printer
My HP 940C only prints in shades of red. I replaced with new HP 15 & 78 Cartridges, still have same problem!
Some HP ink refills have the exact same product number but the electrical contact tips on the back of the cartridge are not the same configuration, resulting in red ink only being printed. One example is the DeskJet color ink cartridge C1823D having multiple configurations.Find a printer just like yours that's working properly and compare the contact tips if possible. HP tech help is a joke on this one. Good luck!
Dec 29, 2009 | HP DeskJet 940c InkJet Printer
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Pictures look fuzzy and not sharp when i print them . Does my printer need cleaned? Or is it time for a new printer. Mine is about 8 years old.
Try to replace a new cartridge for your printer...I think your printer is working properly...
if the phenomenon still exist..
its better to flash it with a new firmware.
maybe the signal that the printer sent to the cartridge is not enough...^_^
May 13, 2009 | HP DeskJet F380 All-In-One Printer
Color cartridge in Deskjet Cse is printing pink...Why?
Refilling is all right. I do it all the time! If the cartridge sits for a long time, the ink will dry up on the tiny jets. You may try wiping them with a cloth dampened with water and then running through a purge cycle on the printer. If that doesn't work, then you should go ahead and get it refilled.
Apr 21, 2009 | HP Deskjet 2360 InkJet Printer
HP 5150 Photo Printing Problem
DONT WORRY .UR CARTRIDGE IS OKAY.MAY BE THERE IS SOME MIXING OF INK ON UR CARTRIDGE PRINTING NOZZLE. JUST KEEP THE NOZZLE OF UR CARTRIDGE ON DRY TISSUE SO AS TO **** OUT THE MIXED INK.KEEP IT FOR ATLEAST 15 MINS AND REINSTALL CARTRIDGE.IT MUST PRINT PROPERLY. HOPE U SUCCESS .BYE.
Jun 03, 2008 | HP DeskJet 5150 InkJet Printer
Vista with IE7
why dont u check HP deskjet website for printer driver update? may be its avaible there.
May 29, 2008 | HP DeskJet 5650 InkJet Printer
Printer Prolems
I would start by replacing the printer cartridges with new ones. If that doesn't work then try replacing the software like this:
1. Unplug usb cable at printer.
2. From control panel > Printers uninstall all printers.
3. Reboot
4. Reinstall Printer software
5. Plug usb cable back into printer.
Hope that helps...
Geno
Mar 10, 2008 | HP Deskjet F340 All-In-One Printer
428 people viewed this question
jasbo
jasbo
