Samsung washing machine wa7584c1 power is on, programming seems fine, push start and nothing happens,except water flows ok, no washing no spinning no draining
  • Washing Mach... Master
  • 1,525 Answers
Hello check the belt first to see if it's come off or snaped if ok then the fault could be the brushes on the motor 2 plastic blocks sit either side of the motor they wear down can cause the motor to stop working they just slide out hope it helps
regards
shaun
Posted on Mar 13, 2011
Water reuse error
I also face the water reuse error problem on the top loading Whirlpool washing machine. Powering on is OK. selecting the program also goes fine. The moment start/pause button is pressed, little water flows to draw detergent and immediately the "water reuse" LED lights on. Further to that nothing happens. Any solution?
Oct 16, 2013 | Whirlpool Washing Machines
My washer WA7584c1 is realising water when its on a processes of wahing?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 19, 2013 | Washing Machines
Samsung washer won't fill with water
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 04, 2012 | Select Brands Washing Machines
Samsung washer wont spin
Check this link for tips;
Jun 28, 2012 | Samsung WF337AA Front Load Washer
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
I have a fisher paykel smart drive 7,5 kg was working fine and the other day it just stopped no lights to indacate the powers on no beep wen u push the button just make a slight humming noise wen you press...
The humming noise can be fault in the motor or a fault in the capacitor to the motor.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 17, 2011 | Fisher and Paykel Washing Machines
Washer flashing spin light...can't cancel.... tried to reset by unplugging washer, tried starting a new cycle....nothing happens. Can't get door to unlock or washer to start.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Seems that the controller is a suspect as it fails to move forward with the program/ Also check the function before we conclude.
Aug 12, 2011 | Kenmore HE2 Plus Front Load Washer
My indesit WIL123 stopped mid-wash with LEDs 3 & 4 flashing with the main button. Pushed the main off button on the machine and it started to fill with water again. Now have a washing machine full of...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 22, 2011 | Washing Machines
Every 3 loads I get nd - not draining and must drain, spin, x 1 or 2 before I can wash again. EEK! Sometimes absolutely NOTHING seems to come out except water but this always happens (Samsung Silver 2007)
this machine has suffered a power failure at sometime,to reset push and holt the main power button along with an other button hold both in at the same time and this should reset the program hold for about 60 secounds.adrian.
Mar 16, 2011 | Samsung Washing Machines
The wash cycle doesn't work, but spin cycle works!
Did you ever find out what was wrong with your washer?
Mar 23, 2009 | Whirlpool Washing Machines
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
