Question about Fisher and Paykel Refrigerators
My fridge seems to be getting hot on either side.. The fridge has not been used for a while.. Is this a problem and if so what do i need to do Thanks James
  • Fisher and P... Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Fridge does not seem cold enough. It is maybe 12 years old. Do I need a new fridge
The heat between the doors is normal but not really hot. if sides and between the doors is real hot then you have an air flow problem. Vacuum coils under it and coils by condenser fan. Check your Condenser fan by compressor.
Jul 28, 2013 | Refrigerators
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Freezer not getting cold.
best way is let the repair man check it
Nov 22, 2017 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Hot point Fridge/ freezer
All the cooling is in the freezer and the control in the fridge side only controls a damper to let in cold air as needed. To do what you want you have to replace the thermostat to a lower temp rated unit
Nov 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Freezer Drain Clogged
I use a turkey baster and force hot water right down the drain hole. If still blocked I push a coat hanger wire down the drain, usually works but you need patience with the hot water.
Jun 17, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
41 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
