Question about Panasonic CQ-DF802U CD Player
My face plate middle lights went out the volume and menu lights work. What is the problem. is it trash is it a simple fix.
3 Suggested Answers
  • 2318 Answers
SOURCE: face plate is black
The 12 volts lights that illuminate the face plate are burnt inside and should be replace. It's a common failure on any face plate.
Posted on May 04, 2008
  • 26 Answers
SOURCE: face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Posted on Jan 21, 2009
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
Just bought a Sony KV-27ts20 second hand. Great
There might be another solution beside the trash can. You see often with audio problem the fault is the audio output i.c that is gone. Also in the tv menu you may have speaker on/off, make sure they are on. If it still doesn`t work then you may want to try the audio out connectors at the back of the set,there may be sound there. What you`ll need is and audio system with aux/cd/tape input and a rca/phono stereo cable. Just connect the tv out to any free input and turn up the volume .
By the way the tv audio out may be variable(option in the audio menu) which means that any amplified speakers(computer speakers) could be used as long as you have rca connectors on the end of it.
Hope this will help. Good luck
Dec 04, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Face plate buttons wont work
Jan 20, 2009 | Alpine CDM-7874 CD Player
Annoying blue light on volume control.. can it be turned off?
The face plate is easy to take apart, just remove the face plate off the head unit and take the hex screws out and put a piece of tape over the bulb on the system board. Then put it back together again.
Nov 03, 2008 | Kenwood KDC-MP238 CD Player
Face plate is black
May 04, 2008 | Panasonic CQ-DF802U CD Player
Yellow box with the letter "K" in it.
the TV needs to be reset with the Factory Initialization. Try contacting Sharp at 1-800-327-4277 for instructions.
Sep 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Panasonic CQ-DF802U CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
