Question about Intel DP45SG Motherboard
New system. Cannot enter bios with F2 key, apparently keyboard is not working, but works well in another computer. I tried bios switches 1_2 default and 2_3. With 1_2 it goes directly to PXE_E61 error, with 2_3 it goes to bios page, but nothing can be changed with the keyboard. Pressing F2 or F10 after beep has no effect. Couls you help?
  • 28 Answers
Hallo there, tried the DEL key? (instead of the F2, some Bios of them use older input for F2, DEL sends same key. )
Also, please count how many short, how many long beeps mopbo gives when booting.
Also: try to connect with PS2 keyboard. Possible no correct keyboard connection or even worse, when its a wireless keyboard need tyo pair keyboard with receiver first.
Also possible: is the keyboard not IBM compatible?
As said: try first to use default PS2 keyboard, theyre cheap and most of the times problem is directly solved.
If that does not solve your problem, count the beep codes and tell us please, could be some other problem, ( wrong memory, memory not placed correct, voltage problems etc etc etc)
the bios codes would help us to help you fasst.
Greetings
Ganimidis
Posted on Mar 13, 2011
  • 93 Answers
I think you are using a USB keyboard. Try with a regular PS2 keyboard and enable the USB keyboard from BIOS. Then switch to your USB keyboard.
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Function keys do not work on Linux
Hello!! try updating K Desktop environment ... even my friend had a similar problem ... he resolved it after updating ... hope it works ... Bye
Dec 07, 2007 | Toshiba G83C0001K210 Keyboard
What keys change bios values on asus u46e
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
How to get into bios
try all the f keys at switch on
take note that on some keyboards you may need to press the Funtion key + the f key at the same time
another problem may be an fkey lock on your keyboard
at the start of post ( power on self test ) you will quickly see what key to press to enter your bios
good luck
May 16, 2012 | Intel Computers & Internet
I am unable to activate wireless card. I have to press Fn f2 key but the f2 key on my keboard doesn't work. I tried connecting a wireless keyboard (it doesn't have Fn key), then pressed Fn on laptop, F2...
It could be a drivers problem... Unistall the drivers from the device manager and install a fresh one from the dell website.. Try pressing the FN+F2.. Still no go.. Try to check whether the keyboard is working.. Still no go - resaet the Wireless card... Still no go.. Replace the wireless card..
Sep 06, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron 8000 when I go into cmos(setup)F2, there is no control working. arrow keys do not work
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-630m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Oct 02, 2009 | Dell Inspiron 8000 Notebook
How to enter bios
Hi...
To enter bios it so easy. When you turn on your computer you just only press delete to enter bios. If the bios does not exist you can press also F2.
Regards
PCmania
Aug 10, 2009 | ASUS Computers & Internet
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Dell OptiPlex GX280 PC Desktop
Can't enter BIOS setup with F2
Try using another application that has a use for the F2 key. I'm not totally convinced that your keyboard is good. It is possible for just one key to fail. Happens quite often.
May 08, 2008 | Asrock 775VM800 Motherboard
Intel DP45SG  Motherboard Logo
406 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
